KillWhitey
04-04-2004, 02:57 PM
when i got home last night, i tried to set my parking break when the cable snaped and the arm went straight up real easy. this morning, i took it all apart to try and fix it when i realized it was way too short. what do i have to do to put a new cable in the car? is it very hard?
jeff94z28
04-04-2004, 04:00 PM
I have the same problem. I pulled up on it befor and it flew straight up, dropped it back down, pulled up again and it worked fine.
About a month later it happened again. Dropped it back down and pull up, its EXTREMELY tense. I can only pull it up about 2 or 3 clicks til I cant budge it anymore, and thats pulling up very hard.
Ive left it until now but if someone can help me out Id appreciate it. Im afraid to park on hills. Even small inclines my ebrake wont hold.
fredmr39
04-04-2004, 04:35 PM
wow - same thing happened to me 3 days ago - scared the crap outta me --- ripped it up, was very loose all the way up, put it down, all is good.......
KillWhitey
04-05-2004, 01:24 AM
I took mine apart and the cable is broken. Has anybody replaced the cable? Can anybody tell me how difficult it is to replace, with maybe even a step by step guide?
jeff94z28
04-05-2004, 11:33 AM
Hmm so you know why yours is broken, but whys mine super tense. And its not engaged when Im driving, I know that for a fact. Its just really tense to pull up on.
Fatdog
04-05-2004, 11:50 AM
That happened to me about two years ago,and it only did it once,and I thought(what the).Seems it's a common phenonemon. But a couple of months ago I heard a big BANG.Drove it to the mechanic,and had a broken cable.The mechanic suggested I replace both cables,as the other good one was problably streched,so I did.$45.00 for parts plus labor.Hope this helps.
jeff94z28
04-05-2004, 01:18 PM
So fatdog yours got really tense too? Maybe its really tense now cause its out of balance and all the presure is on one side?
Let me know, Id love to get this thing fixed.
KillWhitey
04-06-2004, 12:42 AM
I will fix it myself. is it a big job? What is involved and what do i have to do?
jeff94z28
04-13-2004, 03:57 PM
Anyone have any updates on this topic?
Are their 2 separate cables or just 1?
If 1 of the 2 broke would it cause unequal presure and be really tense to pull it up.
SantaCruz163
05-05-2004, 03:46 PM
I'm in the same boat for a broken e brake cable. I have a brand new replacement (http://community.webshots.com/photo/139300363/139301167wFwmbC) I'm not sure how to install this piece, can anyone tell me the jist of it? The 1st owner said the metal tab broke off that plate.
my94blackz
05-06-2004, 10:11 PM
Im in this boat the end at the rear caliper shattered on mine now i have to replace the driver side cable. Does shoebox have an install guide?
jawzforlife
05-07-2004, 02:24 PM
I had to replace that cable it is very easy. You have to go into the center counsel, and take of the parking brake handel from the car then unhook the 2 cables (that go to the wheels) from the "t" under the car above the drive shaft. The only prob I had was getting the rubber seal back into the floor of the car. I kind of put it in there half assed, if you can get it in there all the way, you a better man than me.
To repalace the cables that go to the wheels, you have to unhook the 2 spots (2 spots per cable) that the cable connects to the under side of the car. Then unhook it from the "t" above the drive shaft. Then unhook it from the brake caliper.
Very easy.
