Live for TAs
04-04-2004, 12:52 PM
I think I have found a decent mounting location for my B&M Super Cooler here (http://images.cardomain.com/member_images/4/web/256000-256999/256387_118_full.jpg) .
My question is about the size of feed/return lines. The cooler has 1/2 NPT fitings, and my cooler adapter has -10 AN fitings. I can run a -10 hose OK, but I also want to add a temp sensor (possibly 2) at the cooler. Aeroquip makes a -8 inline fitting adapter that is perfect for what I want to do, but they do not make this for a -10 line. Will it be a problem if I run -8 hose? It looks like it will be about 7-8 feet one way to the cooler.
The specs are -8 is 7/16" ID, and -10 is 9/16" ID. Most oil cooler kits I've seen for sale use 1/2" ID hose.
I've run a front mount cooler on a rear engine Chevy using -10 hose due to the length involved (12+') and it seems to work well. I used -8 when I added the Supercooler to my SSEi Bonneville (welded fittings on the factory lines & bypassed the radiator "cooler") with no adverse affect, but it was a very short length (2-3').
