stevem
04-02-2004, 03:40 PM
last year i built a 383 for my iroc and now am going to put a 6 speed in it.Will i have to balance the flywheel and will the flywheel off of an LT1 bolt on.
i had to balance the flexplate last year when i built the 383
TheGreatJ
04-02-2004, 06:58 PM
If it's a late-model (1-piece RMS) engine then the LT1 flywheel will bolt up. If it's a 2-piece block you'll need a conversion flywheel.
Since you had to balance the flexplate, you must have an external-balance crank which means you'll need to balance the flywheel too. You can just take the flexplate off and carry them both to a machine shop and have the flywheel balanced to match the flexplate.
