95camaro3400
04-01-2004, 05:56 PM
i only have brights on my 95 3.4, i noticed yesterday at about 1 pm that i had only 1 regular headlight then maybe an hour later i noticed i had none, ive been having to use my brights everywere i go, i can t even find a fuse for them, i looked at the bulbs and they are both good, and one was even replaced about a month ago, any help is greatly appreciated
99blackSS
04-01-2004, 07:22 PM
The fuse is probably on the drivers side of the dash board.
95camaro3400
04-01-2004, 07:57 PM
ive looked everywhere and i cannot find a fuse i looked under the fuse panel on driver side and under the hood, any ideas what it could be, im thinkin headlight switch?
99blackSS
04-01-2004, 08:40 PM
I doubt it is the fuse because they are probably on the same fuse which would make it hard for them to go out at different times. Try using a continuity tester to see if the power is getting to the sockets.
user name
04-02-2004, 02:44 AM
listen to 99SS. think about it. the switch feeds power to the multi function switch, which feeds juice to both headlights' low beams. so if you lost something that far upstream, you would have lost both lights at once.
grab a test light and check each connector for juice. go from there.
good luck.
