450+ Hp 383
Old Mar 30, 2004 | 06:17 PM
CraigS's Avatar
450+ Hp 383
I have the makings of an engine that should net 450+ horsepower. All new in the box (assembly required) $2000.
Block: Seasoned Chevy 350 block with 4 bolt mains. Needs machining .30 over and clearanceing for stroker crank.
Stroker kit: Speed-O-Motive 383 with high nodular Iron 3.750 crank, 5140 forged 6" I-Beam rods with ARP wave lock bolts, KB light weight hypereutectic flat top pistons 10.2:1, Speed pro cast rings, Clevite tri-metal main and rod bearings.
Cam: Comp Cams # 12-246-3, 230/236 duration @ .05, .487/498 lift. Pete Jackson gear drive.
Lifters: Summit Hydraulic. Push Rods: Summit Chromoly hardened.
Rocker Arms: 1.6 ratio aluminum fully roller Scorpion
Heads: World Products Sportsman II, angle plug, 200cc intake runners, 64cc combustion chambers, 2.02/1.60 valves. Bare
Valves: Manley 2.02 intake, 1.60 exhaust, stainless steel swirl polished.
Springs: Comp Cams # 981-16.
Retainers: Comp Cams # 742-16. Locks: Comp Cams # 601-16.
Guide Plates: Comp Cams # 4806-8. Screw in Studs: Summit 3/8.
Intake: Victor JR single plane. Carburetor: Speed Demon 750 double pumper
Oil pan: 8 quart high capacity with crank scraper and windage tray.
Balancing: Chevy 400 176 tooth flywheel, Chevy 400 chrome fluid harmonic balancer
ManglerX@sbcglobal.net or 916-719-2504
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
