pontiac ?
anuarism
03-30-2004, 04:29 PM
So what is the difference between a pontiac 400 and 455, bore or stroke or both?
2000zee28
03-30-2004, 08:38 PM
455
Engine Code WT, WW, ZZ, ZE
Engine RPO L75
Displacement 455 CID
Bore x Stroke 4.1522" x 4.121"
Compression Ratio 7.6:1
Horsepower @ RPM 200@4000
Torque (Lb/Ft) @ RPM 330@2800
Head Casting 7F6
Carburetor 4-bbl
Carburetor - Federal 7043273
Camshaft
Part #
Lift, I/E NA / NA
Rocker Arm Ratio 1.5:1
Duration I/E - Degrees NA / NA
Overlap - Degrees NA
Intake Valve Dia - 2.11"
Exhaust Valve - Dia 1.66"
400
Engine Code WT
Engine RPO L78
Displacement 400 CID
Bore x Stroke 4.1212" x 3.750"
Horsepower @ RPM 185@3600
Torque (Lb/Ft) @ RPM 310@1600
Head Casting 5C
Carburetor 4-bbl
Carburetor - Federal 7045263
Intake Manifold 495106
Camshaft
Part #
Lift, I/E .377 / .415
Duration I/E - Degrees 269 / 282
Overlap - Degrees 59
IRONFIST
03-31-2004, 02:03 AM
you can stroke a 400 to 455.. so not much:cool:
Dave89IROC
04-01-2004, 06:55 PM
you can take a 400, bore it .030 and use a 455 strock crank
quicksilver97ta
04-02-2004, 10:32 AM
Both. But you can't just drop-in a 455 crank, they have a larger main journal size than the 400. Go check out "pontiacdude.cc" lots of cool pontiac build-up stuff.
Dave89IROC
04-02-2004, 03:18 PM
I meant to say 455 stroke crank, I knew the mains were different
