1 DWN CAM
03-28-2004, 04:23 PM
I have a Nitrous Express Shark Direct Port system from 1998. Back then they supplied the system with one nitrous and one fuel selinoid, and a distribution block to all 16 lines. Now with the new Shark systems they give you 2 of each selinoids, and instead of the distribution block they give you 2 red and 2 blue fuel and nitrous rails. My question is What's the PN# for these rails. Both red and blue? I could not find them in the new catalog.
Thanks.
Nitrous Crazed
03-29-2004, 10:47 AM
Actually the kit you are talking about is a different kit.They still carry the kit you have also.The kit you have ie an 80000EFI
The kit you are looking at is Pro Sark 90006 it also comes standard with the distribution block and the rails are a seperate charge.The part number for the rail upgrade is 90001.
1 DWN CAM
03-29-2004, 03:26 PM
OK, so if I just wanted to buy the rails (total of 4) it would be PN 90001? What do these rails go for? $$$. Also What size fuel and nitrous selinoid does NX supply with this shark kit I already have? So I may buy 2 more.
Thanks for your info.
CustomN2O
03-30-2004, 01:17 AM
The solenoids you have with the "2 solenoid" shark kit is a .125 Nitrous, and a .312 Fuel. If you want to upgrade to the rails, Jobber price on that is $315. What you can actually buy them for varies from place to place. Now I think you might not be talking about the full rails. I think you are referring to the short "rail" distribution blocks. Those arent in the catalog, but you can get them. The are about 3 inches long. 2 nitrous and 2 fuel. IF you need any more info on them, you can give me a call and I can fill you in, or email me. Those arent nearly as much as the full rail system.
Scott
925-998-1517
