BlackbirdWS6
03-28-2004, 09:56 AM
runnin a TNT wet kit on my LT1, went for a run vs a modded GSX eclipse. I was runnin 1050psi or so on the first run and pulled him, second run only had 850 in the tank and we were dead even up top. How much power do u think i gave up in bottle pressure???
juiced_lt1
03-31-2004, 11:17 AM
Apparently you weren't running a big enough shot, you shoulda raped him. =)
depends onthe shot really, a 50shot doesn't take much pressure to flow correctly, whereas a 150shot takes a lot more pressure to flow correctly. If it doesn't flow right, you'll run real rich and that's what kills your power. I run 1150psi, and can spray all the way down the track, and my pressure only drops to MAYBE 1100 on a full bottle.
BlackbirdWS6
04-02-2004, 01:27 PM
yea im runnin a 100 shot wet. like i said, on the first run it would have gotten very very ugly but on the second is was dead even with me slowly pullin in 4th... btw he is running a larger turbo and over 25psi of boost. thanks for the reply
