RR question??
2MUCHZ
03-27-2004, 01:28 PM
Hey guys a just put a set of 1.6 rockers on my car but the stock valve covers will not work not tall enough.....did anybody else have this problem.....if so where did you find a set of tall style centerbolt valve covers......i tried converting a regular tall style Small block set but cant get them to seal properly.....thanks alot
PhantomTA
03-27-2004, 01:31 PM
Originally posted by 2MUCHZ
Hey guys a just put a set of 1.6 rockers on my car but the stock valve covers will not work not tall enough.....did anybody else have this problem.....if so where did you find a set of tall style centerbolt valve covers......i tried converting a regular tall style Small block set but cant get them to seal properly.....thanks alot you have to clearance the valve covers..
take a dremel and get to work
Black Sunshine/ 00SS
03-27-2004, 02:20 PM
Jegs or Summit. Or just as he said above, and maybe try double gaskets.
2MUCHZ
03-27-2004, 03:24 PM
thanks guys
dreamer1q
03-27-2004, 08:01 PM
Hey PM me with a update on things.
Q
IROC5.7TPI
03-27-2004, 08:31 PM
Theres a company out there that makes a shim that goes between the vc and the head to allow clearance with stock vc's. I'm sure if you look around you'll find what i;m referring to.
97WRAITH
03-27-2004, 11:14 PM
I am using the stock covers with my 1.6 comp pro mags.You can bend the lip on the support ribs closest to the intake.Do a search on LT1 tech.There is a website with detailed pictures on how to do it.
Rob.
