CLOKWRK 03-26-2004, 01:46 PM I have a Flashing SES that my "generic" version of ATAP for palm doesn't detect!?? It shows no DTC's? I've been told that the flashing SES is usually a multiple misfire or a catylitic/emmisions failure. Anybody have a "enhanced" version of ATAP or some scanner that will read/monitor misfires or just tell me what is going on? I'll gladly come to where you are and pay you $20 to hook me up. The wierd thing is that the car car idles/drive great! The SES light flashes when cruising 2000-3000 rpm. Goes off when I come to a stop or slow to under 2000 rpm. If I accelerate through the gears and keep the revs over 3000 rpm it never comes on!!?? :confused: If anyone can lend a hand or give some advise I'd be very grateful. Thanks, -Greg
PhantomTA 03-26-2004, 02:03 PM Its multipul missfires.. And BAD at that.
Ive only seen it when crap was damaged bad in the motor or when a plug wire wasnt put on.
CLOKWRK 03-26-2004, 02:32 PM I'm afraid of that. :cry: I hope that you're wrong, no offence LOL:(
PhantomTA 03-26-2004, 03:17 PM Originally posted by CLOKWRK
Miss a shift? lol
I hope not..
What happened just before the SES?
CLOKWRK 03-26-2004, 03:34 PM Well, this is the part of the story that I didn't post (I may still be in denial LOL): I didn't miss a shift, but I did break a valve spring end of last season cruising around 2000 rpm on the freeway. It's been siting since November. I thought I got lucky 'cause it broke at the top right near the retainer, maybe I wasn't as lucky as I thought. If a valve kissed a piston and bent wouldn't it run rough, backfire and crap? Does anyone have a leakdown tester I could borrow too? :cry:
PhantomTA 03-26-2004, 03:49 PM Originally posted by CLOKWRK
No it could run absolutely fine, with a slight stumble...
You need to do a compression and leak down test..
It might be something as simple as ignition probs.. ie plugs or wires.. etc
CLOKWRK 03-26-2004, 04:12 PM Originally posted by PhantomTA
hmmm...I hope so. I'll have to double check all my elec. connections. I have new plugs and wires though...i'm not getting a good feeling about this. Thanks for the replies/opinions
PhantomTA 03-26-2004, 04:37 PM goodluck man.. keep me updated
CLOKWRK 03-26-2004, 07:12 PM Originally posted by Killerjello
flashing means catalyst damaging misfire (ie. no sprk, or fuel not igniting, thus raw fuel making it to the cat.)
It can come on even if the car is running fine, just means too much unburnt fuel is getting to the cat.
If you throw it on a scanner, it should tell you what cylinder it is.
I dont know if the scanner you used will tell you, but the ones they use at autozone will say what cylinder it is.
Well, if that's the only thing a flashing SES can mean, sounds like my valve probably did get bent then, in which case I think I know what cylinder is misfiring. Very, very :(
ur2slow 03-26-2004, 07:56 PM Hey Greg, Let me know if you still want to scan it. I have a Tech2 and a full version of Autotap available to me that we can use. Sorry to here about your problems.
Jon
CLOKWRK 03-26-2004, 08:08 PM Originally posted by ur2slow
Jon
Hey Jon!
I can't believe you haven't sold your Hawk yet!!:eek:
I think my misfire is probably on cylinder 6, but if you have any time this weekend that I could swing by that'd be great.
kandied91z 03-26-2004, 08:34 PM call greg at pf&e 949-3400 it's a short drive for you and he can check out the codes if needed to help you find your problem.
Black Sunshine/ 00SS 03-26-2004, 10:21 PM I had a similar problem, and it ended up being a bad coil. I'd put the stock plug wires back on to rule that out. Then do a scan to setect a misfire. there should be a code in there if it is flashing.
One easy way to detech a bad coil is to switch one side of the engine with a friend, it will show up immediately if that was it.
Dont rule out a bad plug. Switch those out also.
1BAD86Z 03-27-2004, 02:25 AM hey greg i have a compression tester, but i can get my hands on a leak down if needed. let me know.
CLOKWRK 03-27-2004, 07:53 AM Originally posted by 1BAD86Z
I have a compression tester but if you have access to a Leakdown tester I'll take ya up on that! Let me know when you can get it. Thanks, Greg
IrocSS85 03-27-2004, 08:59 AM hey, I have my tech 2 home from work this weekend. feel free to stop by and we can see what cyl. its on, then sw. the coils, then wires, then plugs to find out if any of those are the problem. Im guessing coil myself. as far as the valve goes, I dont think thats gonna be it. due to it running good at idle. also could be an inj. getting dirty. Ive seen that alot w/part throttle misfires. I dont have my cleaning tool here, but I can bring it home one day this week to clear them out for ya. call my cell if you havent scanned it yet w/jon and want to stop by.
chris
313-655-2983
OneBad98Z 03-27-2004, 10:57 AM whats the chances you just got gas before this happened? i had the same problem with my 98, checked everything, but ended up being water in gas, drove it for a little while untill it was down on gas, then filled it up with some good gas and some dry gas..
just an idea, good luck
later,
Greg
CLOKWRK 03-28-2004, 10:57 AM WOO F*@#$%&* HOO!!!!! Chris, you are the man! :bow: Thank you, Thank you. Went out to Chris' today hooked up the scanner and showed #4 wasn't firing!? l expected the worse. Chris still thought is was a ignition problem...swapped coilpacks and found one of the pins on the coilpack plug was bent. Straightend the pin, pluged it in, started it up and...NO SES LIGHT!!! Now, I hadn't driven it all winter so I thought it was running fine...when it was actually running on 7 cylinders :rolleyes: Well it's running fine now! :D I am sooo frickn' happy! I can hardly type right now! Chris, if you ever need an extra set of hands for wrenching or a parts gopher I'm your man! I owe ya one. Thanks again bro!
IrocSS85 03-28-2004, 01:10 PM no prob. home slice. im happy for ya that thats all it was. was that a fun drive home or what? I cant wait to get mine back together man.
HEY MILAN, OPEN UP ALREADY!
chris
