StudyTime
03-24-2004, 02:36 PM
At first I thought of the air-gap as just nice marketing, but now I'm really wondering.
I know an intake manifold gets pretty hot not matter where you touch it, and I didn't see seperating the runners making that much of a difference, but now I'm wondering if this is the case.
Infact, if (for some weird reason) you wanted to heat the intake charge, you would do what every conventional intake manifold does. Pass the fresh air/fuel right by the hot engine oil and coolant.
BUT the air-gap has a gap here. Not sure why this wasn't produced before the air-gap. It seems like a simple concept.
If you have a conventional intake manifold oil and water flow next to it acting as a heat source for the intake manifold. The intake charge would then flow along this heated aluminum.
With the air-gap the hot oil/water would heat the bottom of the intake and would have to radiate heat up to towards the carb. So heat would have to flow through the surrounding air to heat the plenum.
BUT the runners of the air-gap still touch the lower portion of the manifold. This would only allow heat to conduct its self up the intake manifold.
I would say it WOULD SEEM the air-gap should make for a 'slightly' cooler intake charge, but would it be neglideable? I don't know.
If anyone has a pryometer laying around and both intakes please take some readings for me!?
Aside from that I only have information like this,
http://www.fordmuscle.com/phpBB/viewtopic.php?topic=20690&forum=1
Where someone claims to have went from 13.7's to 12.9's by installing a RPM air-gap.
I'd like to get some before/after intake runner temps if I do decide to go with the air-gap.
No one on the board like paying too much for something that can be had cheaper and does the same thing (unless you pay to take your car to the dealership). So, this leads me to thinking is the air-gap worth the difference in increased price?
I'm leaning towards yes, but if you have any further reasoning or any source that you would like to quote... please contribute.
The intakes I am looking at are:
http://store.summitracing.com/partdetail.asp?part=EDL%2D7116
http://store.summitracing.com/partdetail.asp?part=EDL%2D7516
(ALSO BOTH INTAKES ARE AVAILABLE FROM
www.cnc-motorsports.com in an off brand)
These are all for my 350HO Gm crate engine. Dyno sheets from carcraft for this engine can be found at
http://www.carcraft.com/projectbuild/116_0403_mail/index.html
This intake is for that motor with a 750 double pumper on it and 1.625" headers. The motor spins a 2400 rpm (cheap) B&M converter. It's geared with 3.42:1 gears and is 90% street driven.
So, it is marketing or is the air-gap any better than the vortec RPM?
Ben T.
Ben T.
