Moving Sale, and parting out motor
Well I put a down payment on a house and will be moving in about 6 months so this stuff needs to go.
Everything came off my 95 Z or 94 Formula that was wrecked.
red powdercoated intake $85
Black powdercoated stock valve covers $35
March underdrive pulley $40
Moroso blueprinted oil pump and Canton pickup $50
stock injecors $50
water pump $25
Rotating assembly with ARP bolts (Had low oil pressure) FREE WITH BLOCK
Block $350
10 bolt rear end GM 3.73 gears, Torsen diff, TA cover with studs and relocation brackets welded on.
I also have the rear brakes in a box. $500 NOW $450
mini spare $15
panhard rod $5
sway bars front and rear $5/each
air pump with K&N filter attached $10
intake elbow with resonator $30 (auction site sale)
White camaro rear spoiler $10 (SALE PENDING)
LT1 crank (had 2 spun rods, needs a turning) $10
LT1 crank hub $25
alternator $20 (SALE PENDING)
AC compressor $20
stock shifter with ball $25
Camaro cassette radio $50
Formula black driver's side mirror $10
Formula cassette radio $50
95 Camaro center console SOLD
94 Formula Taillights SOLD
AS&M ported 52mm TB SOLD
Hurst Competition shifter (no ball) SOLD
Leather seat, pass front from a Trans Am SOLD
SVO 36# injectors SOLD
Hotcam, Ported heads, Crane 10308 springs, Crane 1.6 RR SOLD
3 Formula rims 16x8 SOLD
Tires 255/50/16 1 good SZ50, 2 good RE940's SOLD
stock posi unit SOLD
stock exhaust manifolds SOLD
Camaro hood insulation SOLD
Driver's side A-pillar. Have 2 SOLD
Pickup much preferred. All items plus shipping from Crystal Lake Il.
More items coming as I go thru my stuff.
Mike G.
stock injecors $50
water pump $25
Block $350
mini spare $15
panhard rod $5
LT1 crank hub $25
AC compressor $20
Mike G.
I need two things. I need a good dipstick for the oil, and I need the upper oil pump drive that fits under the intake. If you have them, drop me a email. I will take them
Q
dreamer1q@michiganspeed.com
Q
Do you by any chance have a low coolant sensor, hatch struts, the little rubber stoppers for the hood (four of them i think), glovebox latch, console lid, still have the short shifter and leather seat for trans am, is it gray? dfanger@suddath.com or setablazebyyou@yahoo.com thanks!
