Noise commin from rear of car
Old Mar 23, 2004 | 09:46 PM
Killaz's Avatar
Angry Noise commin from rear of car
Ok guys. There is this noise that comes from the back driverside of the car when i go over bumps. It sounds like two pieces of tim being slaped together. I have checked the obvious, like the exhaust pipe hitting the rear diff, and heat sheild. I checked the breaks and all was tight. This sound is sooo anoying, even the local tire shop found nothing. Any help would be great.
Holla
Old Mar 24, 2004 | 12:12 AM
VegasZ's Avatar
The rear springs tend to squeak on their bottom metal perches. Just put some grease where the spring sits on the perch and it will go away.
Old Mar 25, 2004 | 03:20 AM
Killaz's Avatar
any other ideas
Old Mar 25, 2004 | 03:30 AM
coogsLS1's Avatar
Old Mar 25, 2004 | 06:50 PM
jm8881's Avatar
I have that same anoying problem. How much grease and how often do you put it on?
Old Mar 25, 2004 | 07:19 PM
VegasZ's Avatar
Just dab some right where the spring contacts the perch. Whenever im down there i redo it. Once a year is enough.
Old May 27, 2004 | 09:00 PM
Camaro2000's Avatar
Try tightening the clamps on your loudmouth exhaust. Hope this helps.
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
