Is it possible to have a motor that won't ping regardless of the amount of advance?
davepl
03-23-2004, 10:31 PM
I have a 396LT4 with 9.0:1 compression, good quench, and 92 octane fuel.
It will not ping no matter how much timing I dial in.
Could it be that this motor won't detonate on too much advance alone?
Stephen 87 IROC
03-23-2004, 11:56 PM
How do you know it's not pinging? An engine will only ping under load. A computer controlled engine will detect ping (knock) and automatically retard the timing. If everything is working properly, you'll probably never hear a ping and will only notice a slight lack of power.
Now if you're using a scan tool to watch for any pinging that's a differnet story.
My engine burns alcohol. Even with 13:1 compression I can have my timing far advanced and it won't ping.
davepl
03-24-2004, 12:00 AM
Yes, I was logging and saw no detected ping or retard. Even at 35, 40, 50, and 60 degrees total advance.
It was obviously losing power the more I went, but I wanted to see how far before it would knock, and it never did, and I thought that was weird!
12Second3rdgen
03-24-2004, 12:16 AM
If you think about how an internal combustion engine works, you will eventually reach a point where the spark really isnt doing anything. I am surprised your motor even ran with that much timing.
Pro Stock John
03-24-2004, 11:51 AM
Keep messing with it and you will fu%% up the motor. Hope you have not made any runs with all that timing.
davepl
03-24-2004, 12:07 PM
Really? How? Exactly how will too much timing with no detonation harm the motor, oh wise one?
Pro Stock John
03-24-2004, 12:21 PM
Even if it does not audibly ping it's running too hot and you are going to burn stuff inside. I saw it happen on a Procharged LT1 WS6. You eventually burn head gaskets.
12Second3rdgen
03-24-2004, 12:58 PM
I know you arent talking to me but to add to this, you are eventually going to reach a point where you you are sparking before the intake valve has even closed, so any cylinder pressure made is going to be blown back up the intake. That is why a lot of times when someone tries to start a car with too much advance, if their starter will even turn the motor over, that you get those narly flames coming out of the carb/tb.
Stephen 87 IROC
03-24-2004, 09:56 PM
I'm kinda wondering if the advance you think you're setting the engine to is actually advancing? Maybe it's not changing at all hence no pinging.
Pro Stock John
03-25-2004, 10:58 AM
Good point Steve.
4drLT4
03-25-2004, 11:43 AM
Yeah...can't imagine advancing the timing that severely, without the consequences of your actions showing up on a logger. Either way, it's not a grand idea to push the envelope that way, as mentioned above.
Injuneer
03-25-2004, 04:28 PM
Are you doing all this with the stock LT1 PCM? How are you changing timing? What are you using for data logging?
EddieP
03-25-2004, 11:18 PM
I had a buddy in college that drove a 3rd gen with DFI, and swore up that the 50* of total timing he ran produced the most power and was safe... I didn't see how he was getting away with so much timing, but he insisted it would be fine (couldn't hear any knock). Anyway, I was helping him do an oil change a few weeks later and came across something rather interesting... the magnetic drain plug was covered with large chunks of piston rings! He's now a mechanical engineer for ford doing engine calibration of all things.... guess he knows better now!
Botch
03-31-2004, 03:48 PM
And I wondered why my F-150 pings on 87 octane.........?:D
