cheap TIG welder?
stone4779
03-22-2004, 10:38 PM
What kind of TIG welder would I need for fabbing stainless steel turbo manifolds?
My uncle used to do heavy welding back in the day, and I think I can get him to show me how to do some cool stuff
The #1 question......
Where can I get such a welder for cheap?
Serene
03-23-2004, 12:45 AM
*shrug* TIG welders arent cheap. You can buy a TIG torch and adapt it to a power supply or a MIG welder, but its no where near the capabilities of a true TIG machine
SMOKNZ
03-23-2004, 04:36 PM
You might find this thread interesting!
http://www.turbomustangs.com/forums/showthread.php?s=&threadid=8872
Bill
stone4779
03-24-2004, 12:07 AM
the most i can probably spend (or want to spend) on a TIG is $800
is there one out there for that price or under?
the only ones I have seen are expensive as hell, the cheapest being $900
Rob(94Hawk#319)
03-24-2004, 12:21 AM
Dude, did you see the link SMOKNZ posted? It's all about the cheapness (is that even a word?).
In total agreeance,
Rob
PatriotTA
03-24-2004, 10:09 PM
Bill
Wow that is some crazy engineering. :D
I know TIG welders aren't cheap, so I just use the one at school - its a water cooled Lincoln Electric. ;)
stone4779
03-26-2004, 05:24 PM
i really wnt a real one, nice and new.
I was hoping I could get away with spending $800 for one bust I guess Ill have to up it a bit.
thanks anyways, I might get bored one day and do that home made one up there.
jonaddis84
03-26-2004, 07:43 PM
Im going to say I doubt it, but you might be able to get a little guy for 1000. Im about to buy the lincoln precision tig 185 as soon as somebody gets one in (brand new model). That one runs $1800~, thats the package with torch and everything.
More than most anyone could ever need, unless doing very heavy aluminum fabrication (thicker than 1/2")
If you want a sweetass tig, check out lincon and millers invertors. They require very little power, but are 200+amp machines, and they are only 50lbs, of course they are almost $3g without accessories
sseeya
03-26-2004, 10:15 PM
You could always get a Hobart Stickmate LX AC/DC welder from Harbor Freight for around $400 and buy a conversion kit from these guys http://www.tigdepot.com/products/p35TD-BBTF.htm for around $250. That's under you $800 budget.
Actually Tig Depot has that setup for around $1600
SMOKNZ
03-26-2004, 10:36 PM
I just bought the same model, Lincoln Precision TIG 185 (still waiting for it to get in) for $1375 at our local Airtech welding store. It comes without the cart so I'll have to build one (thats why it was so cheap) Looks like a nice unit!
jonaddis84
03-26-2004, 11:22 PM
Let me know when you get that in, Im waiting for someplace around here to get a model in so I can try it out, Im used to our $4000-$5000 squarwave 350s and such as school and want to make sure this will make me happy enough.
Also, I was just quoting Lincolns price, you can find it for different prices if you shop, Ive found it for low 1500s around here w/o cart, still a really good deal IMO
oil pan 4
03-27-2004, 06:40 AM
You get what you pay for.
I just ordered a new miller plasma cutter that can hack through 7/8'' steel. Not cheap, but I know it will do what I need.
I'll be looking for a new TIG when I go state side and I plan to pay more than I did for the plasma cutter.
You can try to get a used one from ebay or a rebuilt 1 on if you have a little more $$$.
SMOKNZ
03-27-2004, 06:59 AM
At work we have a Lincoln square wave 175. It welds anythin we can throw at it including Aluminum in any thickness that one would ever use on a car or home project. Since the 185 is a step up I can only imagine that it will be as good or better. As for miller, I have used both machines and really don't have a preference. The only reason I didn't go with the miller TIG was the Lincoln came with a pulser for free. This feature would be really nice for welding up intercoolers near the fins. Debating over miller and Lincoln is like debating Ford vs. Chevy. Both can be effective in the hands of someone who knows what they are doing.
jimlab
03-27-2004, 01:24 PM
www.weldingmart.com often has specials on welders. I bought my Lincoln SP-135T from them, and at that time, it came with a free cart for $429 or something like that. I believe they had free shipping on Lincoln welders at that time too. They have the Miller EconoTig for $1,330 right now, although I know that's more than you wanted to spend.
Keep in mind that just buying the welder doesn't always get you everything you need. You'll still need a good welding mask, and a bottle filled with whatever mix is recommended for stainless. A 40-lb. bottle of "steel mix" (25% argon/75% CO2) cost me another $120 or so, IIRC. I bought the bottle, though, instead of "renting". A good auto-darkening mask will add at least another $80-90, even if you get one on sale. I got a Jackson "Master" variable for $139 from somewhere else (sorry, it's been awhile). weldingmart wants $208 for the same helmet. Also, the cheaper TIG welders usually don't come with the torch... they're just stick welders out of the box.
One option is to just get a good MIG welder and tack your parts together yourself, then take them to someone to finish off with a TIG. It's more hassle, but cheaper in the long run probably, especially if you're not a great welder already. I bought the SP-135T because A) I was limitd to 110V in my garage without some rewiring, and B) because I'm not a good welder, and all I needed to do was be able to fabricate welding jigs and tack things together for my fabricator, who is an artist with a TIG. :)
Hope that helps. Good luck!
OldSStroker
03-27-2004, 08:32 PM
Originally posted by jimlab
[url]
Excellent suggestion! That's what we do, BTW.
nosfed
03-29-2004, 10:39 AM
Ebay is THE place to find a reasonably priced TIG. On turbo hot parts, you'll have to purge the inside of the tube with gas or the welds will crack.
stone4779
03-29-2004, 08:46 PM
yeah i might just do that...
get a good MIG and have someone whos a pro finish it off.
I have never done any welding except for exhaust (header and back) so I guess I should start small first anyways.
Thanks guys. Im still gonna look on ebay for a tig just in case.. never know, might find a good deal!
rtracy
04-03-2004, 09:39 AM
Hey stone,
I have the square wave 175 and I am going to purchase a precision 185 because the precision 185 has more options. The 175 has an automatic post flow of about 9 second that can't be changed. It is a waste of gas. But for little aluminum jobs it is fine (welds great).
The 185 has a adjustible post flow for the gas, it has a pulser for pulsed welding and it has a ac balance adjustment for penatration. The 185 is a much better unit than the 175 because of thoughs adjustments. If you are going to use the welder for alot of aluminum I would suggest getting a water cold torch for the unit.
Anyhoo, you can look at spending 1800 to 3000 for that unit depending on what you get with it. Argon tank seperate. I would not go anything less because it is going to be junk. What I mean by junk is that it isn't going to weld good at all. Unless you can pic up a used one.
Or if you would like, you could send it to me and I could weld it for you. Hope this helps!
jonaddis84
04-05-2004, 09:13 PM
Make sure you look into your input power.
I was gonna get the precision 185, but it draws 64amps at 185 output on 230, which is more than we have in our garage (underpowerd I know).
So I have to spend an extra >$1000 on the invertec 205, but damn, that things badass. Only draws like 20 amps at 205 output..100% duty cycle at 160amps...can run on 115 up to 150 amps. Not to mention 33lbs!
