F/s 94z28 All New
Old Mar 22, 2004 | 01:13 PM
ONTHJUG's Avatar
F/s 94z28 All New
94 Z For Sale Just finished ground up rebuild.94 z28,355 with polished rods,turned and polished,oil holes radiused crank,KB pistons,c/a rings,new oil pump and new pan,all block work,new Lt4 heads with stainless valves and hot cam kit with 1.6 rockers,Trick Flow C/moly pushrods, and LT4 intake,new roller lifters and timing chain and gears,switched over to Fluidampner bolt on balancer,new belt,new sensors,MSD digital 6 ignition,MSD wires,new battery,svo 30lb injectors, new fuel pump GMS and filter,ported Maf,52mm tb,radiaotor roddded and pressure checked,new steering rack,new starter,new ball joints and all poly bushings,CAI,hooker super comp coated headers,new opti,water pump etc.4L60E built with Art Carr parts,Vigilante 3500 converter,deep pan,aluminun driveshaft,Mufflex 4" exaust w/spintech muffler,all Spohn suspension,lowers,adjustable panhard,strut tower brace,adjustable torque arm etc,mac welded subframe connectors,rear control arm lowering brackets,eibach sportline progressive rate lowering springs,new shocks,struts,Roh sp 17" x 9.5 wheels,new Kumho tires,4.10 rear end new Eaton posi,rear cover girdle, new slotted and drilled rotors,new pads, so much more. New interior seats,custom door panels,carpet,headliner and visors,dash top, airbags removed and grant leather wheel,new stereo system,Alpine and Phoenix glod etc,Everything works dark tinted windows,t/top car has inserts, car is black,could use paint but looks good. So many new parts left out would need to call has 800 miles on it. drives perfect. Has new shifter bezel and ****,new wiper motor,has 150 nos system installed. CAR IS VERY POWERFUL YET VERY STREETABLE
THIS CAR WAS NOT WRECKED!!!!!!!!!!!!!!!!!!!!!!
SERIOUS BUYERS CAN HAVE THE VIN FOR CARFAX
INCREDIBLE CONDITION
NEED TO SELL ASAP TO SETTLE TAXES!!!!!!!!!!!
$8500.00 OBO
NO TRADES
IF YOU DONT HAVE THE MONEY DONT WASTE OUR TIME,THANKS
Old Mar 23, 2004 | 08:13 AM
ONTHJUG's Avatar
TTT
Old Mar 24, 2004 | 06:58 AM
ONTHJUG's Avatar
TTT
dalynchmob
Feb 19, 2015 07:20 PM
6-speeder
Aug 26, 2004 08:54 AM
Charged
Feb 3, 2004 04:29 PM
docsis_stretch
Jan 23, 2004 02:42 AM
Firehawk#69
Nov 9, 2003 05:58 PM
