davepl
03-21-2004, 06:27 PM
This started out as a "figure out the high RPM miss under load on my blown 396 w/9psi and a 236/236 cam and 9.0:1 cr", but it's gotten very odd. I could throw parts at it until it goes away, but I'd like to run this by you all for input first.
Since installing this engine I've noticed it likes a lot of advance to idle well (up to about 38-40 degrees at 900rpm) and sounds like its retarded under load. That's purely subjective, but it sounds like I've dialed in a bunch of retard with my Crane's boost-retard dial, but I haven't.
I pulled the blower inlet pipe and started to chase the miss in just normally aspirated mode. I started with 35 degrees of total timing and it there's no miss. So I started adding timing and rerunning, waiting for knock retard or audible ping.
Well I kept right on going past 40... past 50... and up to 60 degrees total advance with no ping and no knock retard in the logs. With 60 degrees the miss was back and much more pronounced under load. So I set it back to 35 and and the miss is gone.
Now as far as I'm concerned there's no way an engine could take 60 degrees of total advance and not ping. So what else could be wrong here?
I know the FAST is at least commanding advance becase it has a big effect down at idle.
I have checked the FAST software and it's set up for a 6 degree crank reference angle (normal for optispark) and 96 uSec inductive delay (standard).
I'm going to pull the Crane out of the mix entirely and see what happens, but I'm very curious to hear other theories!
Thanks,
Dave
Thanks,
Dave
