Freak
03-21-2004, 01:05 PM
hey everybody, like it says in the title, I got a 1968 Camaro yesterday, and I have a few questions about it.
First, will a 2nd gen rear end fit without modification? obviously the brakes will have to be swapped. but is the overall and leafspring width the same? are there anyother problems other than width?
Second, the one bad area of the body is the rodker panel on the pass side. is this a welded on body panel? or is it bolt on?
Third, the headlight connection is an old style, is there an adapter so I can use a newer style light?
Fourth, I want to change the front end to an RS style, is there anywhere that has a list of ALL the parts I need? I know most of the obvious ones, and some of the less obvious, but Id like to find out if I missed anything
Thanks for any help, Im sure Ill have more questions in the not too distant future.
Troy
Troy
