93ZM6Tally
03-21-2004, 09:47 AM
I've recently purchased a used 4-bolt splayed block from a member. The block was for a blower application and has been O-ringed. The car apparently caught fire shortly after the rebuild thus why the engine came up for sale. The block has the three inner billet/splayed main caps and all caps are on ARP studs. The block apparently has very low miles ~150, and after inspecting the block I believe it. My plan was to send the block to the machine shop and have it hot tanked, replace cam bearings, freeze plugs, torque plate honed and all tolerances checked and then pop in a new rotating assembly providing that the tolerances are in line. I wasn't planning on have the block decked but I would base my decision on what the machine shop finds as far as deck height. Using DCR calculators and a Felpro 1074 gasket I come up with this:
Zero Deck .039 Quench 8.36 DCR
.005 Deck .044 Quench 8.26 DCR
Is the zero deck quench above cutting it too close? And if I do have to deck the block, I assume that the O rings have to be removed. What do I do with the block if this is the case. It's been suggested to me that the ring recesses could be filled with liquid nails and then just deck the block. Do I need to even worry about the recesses since they would be covered by the gasket anyways?
If I keep the O-rings can I still use a standard gasket without problem or do I need to find a specialty gasket, and what does this mean as far as compressed height of the gasket?
BTW this is a 383 stoker I'm building here with a 3.75 4340 forged bottom end, 6.00 rods and -5cc dished pistons.
Thanks.
Thanks.
