Twelvz
03-18-2004, 09:39 PM
http://www.davidvizard.com/camshaft.html
Has anyone used this program?
Want to know what experiences people have had before and after or just the results of the CamMaster program
SStrokerAce
03-19-2004, 06:31 PM
I've seen some cam choices from it and it seems pretty basic in some reguards. It will get you close, but you can do better.
Bret
OneFlyn95z28
03-21-2004, 02:49 AM
What he said.
I have also heard of cams being sent out that were not speced as they should
stealthramman
03-23-2004, 11:21 AM
I read an interesting article about a 351 windsor ford with an h.r. cam spec'ed from this cam master program. The engine and cam combo was mild but the engine made over 500 hp, with some big torque numbers also. They gave the cam select program alot of credit for the good output of the motor.
SS MPSTR
03-23-2004, 05:19 PM
Originally posted by stealthramman
I read an interesting article about a 351 windsor ford with an h.r. cam spec'ed from this cam master program. They gave the cam select program alot of credit for the good output of the motor.
Nothing against David, but I'd never expect negative or unsatisfactory reviews within 'sponsored' articles.
stealthramman
03-23-2004, 05:23 PM
I've not run a cam from the cam master program, but David Vizard is a well known engineer and designer and is very well respected in the industry. There must be something to it, coming from this guy.
