I just finished installing springs/shocks...
Achilles97
03-18-2004, 01:36 AM
My car has 72k miles and was on the stock suspension. I installed coilovers with Eibach springs rated at 450 lbs in the front and 175 in the rear. The shocks are Bilstein Heavy Duty.
It took me two days to remove the stock springs/shocks and install Eibach coilovers and Bilstein HD shocks. A few hours were used to adjust the height to where I wanted it. It would have only taken one full day but I didn't have all the necessary tools when I began and I wasn't familiar with suspensions.
If anyone wants to do this job, make sure you have:
- a floor jack
- another jack (spare tire jack)
- jack stands
- sockets and wrenches in standard AND metric (LARGE, at least 7/8")
- Torx 50 bit :rolleyes:
- hammer and rubber mallet
- spring compressor
- Liquid Wrench or equivalent
The rear was easy. It should taken about 2 hours. I didn't have a socket that would fit onto the lower shock bolt so I had to use a wrench but the wrench would only turn about an inch before it hit the ground, so I dug a hole into the pavement to allow me to swing the wrench. When I put in the new shocks, the new bolt/nut was larger so I gave up and walked to a hardware store and bought a socket for it.
The front was more difficult. I didn't realize that I would need a Torx 50 bit to remove 2 of the 4 upper shock mount bolts, so I had to walk back to the hardware store. They only had a 7-piece set of Torx bits and it was about $25. Later, I found a larger set at Autozone for $10. :irk:
You do not have to separate the lower ball joint or the stearing arm. Just remove the brake caliper/rotor, remove the lower shock bolts, disconnect the sway bar, and disconnect the upper A-arm joint. I had a hard time disconnecting the upper A-arm joint, I tried a c-clamp, pickle fork, but I was finally successful when I used anger :mad: and hit (hard) the bolt with a hammer. Use the spare jack to brace the control arm so it is supported from underneath. The jack is useful to lower and raise the assembly to make it easier to reconnect everything.
The spring compressor tool was not as scary as I imagined. Just use common sense and you should be fine.
Anyway, I am happy that I did it. It feels like a new car. When I hit a bump, it's just *bump* and then it's over with. Even though the springs/shocks are a lot stiffer, it seems like I have less rattles because the suspension is absorbing the road better. Before, hitting a bump was a longer process of sloppy bouncing. The car feels more controlled now. Turning is a lot more stable, the car stays flat and I don't lose as much traction in a turn when hitting bumps. Braking feels better too because the car doesn't nose-dive.
To anyone who was unsure if this job was possible - it is. It's not too difficult, you just need the right tools and decent instructions. For me, the results were worth it.
Next will be subframe connectors.
jkipp84
03-18-2004, 04:37 AM
Cool :thumb: Thanks for the write up! Springs & shocks will be my next mod.. Just put some black ZR1's on and I'd like about a 1" drop to get rid of some of that gap. Where did you get the Eibach coil over kit?
Achilles97
03-19-2004, 12:08 AM
I bought my coilover kit off of Ebay. I think you can find them new online for around $400 for the cheaper sets.
Good luck!
OBE1 95Z28
03-19-2004, 12:26 AM
I'm curious of how you adjusted the ride height.
NorthernSS
03-19-2004, 12:34 AM
Yeah man thanks alot for the write up. I am doing a Koni/pro kit install soon and this is very useful. This will also be my first time doing any install on my car so the tool list is great. Thanks!!!!
NorthernSS
03-19-2004, 12:46 AM
Achilles97
03-19-2004, 04:15 PM
Coilovers are adjustable. The spring sits on a large nut that spins up and down a very large bolt.
I measured the ride height with the stock suspension, then after installing the coilovers I just measured the ride height and got it where I wanted it (3/8" lower than stock).
Fastbird93
03-19-2004, 04:30 PM
Nice write up. Was the coil over setup a front only or front and rear??
Achilles97
03-19-2004, 11:20 PM
It's a front and rear coilover setup. The spring rates are 450 lb front and 175 lb rear.
Fastbird93
03-20-2004, 08:25 AM
That's kind of what I was looking for. Will the setup work with any shock, or are they shock specific????
Reason I ask is I'm planning on a set of QA1 12 Ways for the shocks, and I know the front of them are coilover's and adjustable, but the rears aren't. I'm wondering if there's a way to adapt the kit somehow.
Achilles97
03-20-2004, 02:15 PM
I don't know if they would work with the shocks you mentioned. I know they would not work with KYB adjustable shocks because the coilover sleeve would not fit over the shock. You might want to ask Sam Strano in the Autocross forum.
tim95z28
04-16-2004, 05:17 PM
Achillies, thanks for the writeup, I am doing this this week. I got a good laugh out of your digging a hole in the ground to get clearance for your wrench. I need to add that to my shade tree mechanics handbook. LOL. I pride myself in being quite the shade tree mechanic and have never done that!
Also walking to the parts store can take up time, you need to get a girlfriend!
Tim
