stone4779
03-17-2004, 04:26 AM
so is a shaft-mount rocker system worth the price?
What are the benefits, and what are the losses?
Benefits of Shaft-mount rocker kits?stone4779 03-17-2004, 04:26 AM so is a shaft-mount rocker system worth the price? What are the benefits, and what are the losses? strokedTA 03-17-2004, 08:30 AM There are no real down sides, unless you count the price, but if you add up buying guide plates, 7/16 studs, rockers, and a stud girdle, you are about the same. The shaft systems eliminate all those extra parts and you get a lot more stability out of them. Well worth it. Plus with a lot of heads that is you only choice. Mine are T&D's and cost $960.00. Good luck;) Dave Brown kmook 03-17-2004, 09:33 AM http://web.camaross.com/forums/showthread.php?s=&threadid=207006 stone4779 03-17-2004, 01:05 PM thanks | ||
