AHARTZ28
03-15-2004, 10:00 PM
anyone running the SCAT 350 9000 series crank? i ran the 383 crank in mine it was a great cranka nd esy to balance. i spun a bearing and was planning on going 355 or 360 with the scat 9000
thanks Ryan
thanks Ryan
SCAT 350 crank (9000)AHARTZ28 03-15-2004, 10:00 PM anyone running the SCAT 350 9000 series crank? i ran the 383 crank in mine it was a great cranka nd esy to balance. i spun a bearing and was planning on going 355 or 360 with the scat 9000 thanks Ryan SStrokerAce 03-16-2004, 02:37 AM For $250 you can pick up a new Scat 9000 383 crank. They are great for street cars and can handle a good amount of power too. Bret SABLT194 03-16-2004, 06:05 AM Will these cast cranks be reliable under the following conditions: 355 CID putting down 405 ish RWHP - 306 cam - Phils heads Internal Balance- 2 bolt main block I beam Rods KB light pistons Shift RPM 6700 in an M6, PCM limited at 6800 - Launch at 5000 RPM Bracket race 10 passes per weekend every weekend of the season. AHARTZ28 03-16-2004, 07:47 AM Originally posted by SABLT194 Will these cast cranks be reliable under the following conditions: 355 CID putting down 405 ish RWHP - 306 cam - Phils heads Internal Balance- 2 bolt main block I beam Rods KB light pistons Shift RPM 6700 in an M6, PCM limited at 6800 - Launch at 5000 RPM Bracket race 10 passes per weekend every weekend of the season. the 383 i built with the scat crank is great as well, lloks like the 350 one is good as well. i was looking at TRW forged pistons eagle rods witht it as well thanks | ||
