Evacuation Pumps
jdaly
03-14-2004, 09:19 PM
I need the paperwork for a Aerospace Components 4-vane Pump for a dry sump system. I baught the kit used but have no information on it.
OldSStroker
03-15-2004, 10:00 PM
You might start here:
http://www.aerospacecomponents.com/vacp.htm#vp
This probably isn't the right place to post this type of question.
Try this:
http://web.camaross.com/forums/showthread.php?s=&threadid=47092
MaxRaceSoftware
03-18-2004, 03:32 AM
http://www.maxracesoftware.com/BBC_Vac_Pump_4.jpg
i'd always purchase the 4-vane pump , then you can tailor vacuum amount easier to what you want
sometimes 3-vane is not enough
the larger CID of engine
the higher the compression ratio
the worse the rod ratio
the worse the hone job/ring seal
the more the vauum pump will gain Torque and HorsePower
