Temp gauge going buzzerk!
Wishmaster
03-12-2004, 08:30 AM
On my way home yesterday from getting my car dyno'ed...the temp gauge was fine..then all of a sudden it started spiking from bottom to top pegging out.....and was act crazy...just going buzzerk.....and it wouldnt stop.....what could it be? the gauge, temp sensor?
what? why would it do that?
what broke?
unvc92camarors
03-12-2004, 09:03 AM
well, my radiator went out on my v6 and it started stalling, then the temp guage would rise and fall with ease
that might have something to do with it
of course, there was only a crack in the radiator but i needed a whole new one anyways
check for any coolant leaks is my advice
Irocvette355
03-12-2004, 06:32 PM
Either the wire is loose, or the sending unit is going bad...
Get a friend to sit in the car and move the wire around a bit...see if it jumps around. (with the ignition on, or running)
If nothing happens its probably the sensor.
O BTW the sensor is located on the drivers side cylinder head.
Wishmaster
03-12-2004, 06:50 PM
I found it, it was the freakin clip came off the sensor and sat on my header and melted....damnit!...I fixed it though..
thanks guys!
unvc92camarors
03-12-2004, 09:44 PM
thanks guys!
some guys get all the easy problems...:rolleyes: :p
in all seriousness, glad you got it fixed cheap and easy:)
97WS6SCharged
03-12-2004, 10:53 PM
Mmmm... fresh baked plastic. :D
PyRo9862
03-13-2004, 03:09 AM
What someone doesn't like working on there car? :)
aklim
03-13-2004, 11:21 AM
more fun driving than working on it. :D If I wanted to work on it all the time I'd have gotten a Fix Or Repair Daily car. :D :D
