which trans cable can i use?:confused:
z91bowtie
03-12-2004, 12:56 AM
Whats up guys? question i'm getting ready to swap my tpi 305 with a lt1. and i want to know about the trans. i have in it now a 5 speed and the lt1 came with a 4l60e trans so i want to know which cable do i need. 3rd gen or 4th gen? also if i use a stock 3rd gen shifter will i need the 4th gen cable and will this work together if thats the case? i would try using the 5 speed but from what i've read it's not strong enough. thanks for any help.
aklim
03-12-2004, 02:17 AM
Are you talking about the cable that goes from the shifter to the tranny (4L60) or are you talking about the kickdown cable?
97WS6SCharged
03-12-2004, 02:28 AM
The 4L60E doesn't use a kick down cable. As far as shifter cable goes, either should work. :)
Find a 6 speed and you'll look like this... :D
z91bowtie
03-12-2004, 10:59 PM
I'm talking about the one for the gears
z91bowtie
03-12-2004, 11:01 PM
If i had enough money you bet your ass i would buy i 6 speed:D
aklim
03-12-2004, 11:10 PM
I don;t think there is a cable for the rear end gears. For the 4L60, it has a kickdown cable and a shifter cable and a speedo sensor. For the 4L60E, it has the same less the kickdown cable.
z91bowtie
03-12-2004, 11:40 PM
no i mean the one for P R D 2 1 tha trans it's self
aklim
03-13-2004, 01:15 AM
You mean P R N OD D 2 1. You missed out the OD and the N. That is the shifter cable. You can get it from the GM parts store and get the shifter from a JY.
z91bowtie
03-14-2004, 01:24 AM
Thanks for your help. aklim
