SB2 heads/intake on a standard SBC??
Old Aug 11, 2002 | 09:36 PM
z28kid93's Avatar
Post SB2 heads/intake on a standard SBC??
can it be done? or do you have to use a GM Bowtie block. and everything i keep reading talks about a dry sump oiling system. is there a way to convert back to standard type oiling system. also, if it can't, is a dry sump oiling system ok for weekend street use? sorry for dumb question.
Chris
Old Aug 11, 2002 | 10:11 PM
89ProchargedROC's Avatar
Post
Unfortunately i do believe you need to use the SB2 block but i'm pretty sure you can get it to work with a wet sump, you just need some adapters for the block
I remember reading in an older hot rod or possibly car craft where they built one for street use using one of those shops that sells nascar stuff cheap
Honestly, its too much money IMO. If you want that much horsepower, it think it would be much easier to get a set of CNC ported 18* heads used with shaft rockers all setup on a big inch small block (400-427). Thats the better way to go
Old Aug 11, 2002 | 10:16 PM
z28kid93's Avatar
Post
thanks for the advice and info. i'm staring at that article about the wet sump conversion right now. just found it a bit ago. thanks again!
Chris
Old Aug 11, 2002 | 11:28 PM
TAYLORMADE's Avatar
Post
You can use a standard block but you have to use offset lifters on both int. and exh. (which means solid roller only) and you have to drill holes for the spark plug coolant passages. You can buy used cup sb2.2 heads with only 1 to 2 races on them for around 4500.00 to 6000.00 complete with matching intake, Jesels, valve covers, studs, push rods, lifters, valley tray, rest of the top end. But be careful not to buy sb2 or the sb2.2 restrictor plate heads (Usually smaller than 275 cc intake runner) you'll want the 286 cc or bigger heads. This sounds really big but the runners are longer so they are compairable to a 255 cc 18 degree head.
HOPE THAT HELPS
Old Aug 11, 2002 | 11:37 PM
TAYLORMADE's Avatar
Post
P.S.
They sb2.2 is far superior to the 18* stuff and it's dang near impossible to find the good 18* cup stuff as it's hasn't been used for several years now. You won't find any that aren't about used up. The 18* head from the cup guys are chevy castings and are very prone to cracking (major problem). Thats why they only use them once race. The sb2.2 doesn't crack and make about 50 hp more the the 18* head. But be prepaired to spin alot of rpm (358--3.335x4.120-- 9300 rpm) alot less on a bigger engine.
If you want some I can get you some from HENDRICKS or DEI.
[This message has been edited by TAYLORMADE (edited August 12, 2002).]
Old Aug 12, 2002 | 12:36 AM
Larnach's Avatar
Post
WELL if your gonna spend that much on your heads, why not try those Arao babies? You'll spend the same amount, but I guarantee you will have tons more power.
Old Aug 12, 2002 | 12:50 PM
z28kid93's Avatar
Post
thanks for the advice guys.
i haven't heard much about those "Arao" heads? Can you give me any information about them or where to look?
As for the spinning higher RPM, do you mean in durability? I was hoping to do like a 400ci+ motor with these heads/intake. Do you mean then that with the bigger engine I could keep the rpms down? I was planning on redlining at about 8000, so would these be a bad choice?
Old Aug 12, 2002 | 01:18 PM
Post
The arao heads are the 32 valve SBC heads
they require a good deal of fabrication but i wouldn't think much more than a set of SB2 heads
i'm pretty sure that Big Rick is using them
Old Aug 12, 2002 | 01:19 PM
Dr.Mudge's Avatar
Post
Arao (or formerly known as, I forget last status of the company) makes 4 valve per cyl heads for standard single cam SBC, the rockers I think are 1.4:1 that are used with it, you need custom headers, yada yada.
I think I'd stick to something more traditional as your already thinking, 18º, SB2 or whatever.
Old Aug 12, 2002 | 11:07 PM
z28kid93's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by z28kid93:
As for the spinning higher RPM, do you mean in durability? I was hoping to do like a 400ci+ motor with these heads/intake. Do you mean then that with the bigger engine I could keep the rpms down? I was planning on redlining at about 8000, so would these be a bad choice?</font>
anybody got an answer for that Q?
TAYLORMADE-
do you get the stuff directly from those teams? or is there an intermediate you get them from? how much would we be talking? and if there is a good block available i'd be interested in that as well. I dont' need the pistons or crank though. Is there any type of warranty or guarantee on them? Thanks, and if you need to you can email me with prices. I'm not looking to do something right this minute as I'm still setting up suspension/rearend. But I've pretty much decided to go this route. Thanks again.
Chris
Old Aug 13, 2002 | 01:22 AM
TAYLORMADE's Avatar
Post
CHRIS
I've typed a reply twice (real long) and lost it both times. Just Email me at kent02@duh.net and I'll get the info from you to get a price for you and answer you're Questions.
I'm tired of typing-stupid computer.
Old Aug 13, 2002 | 12:46 PM
z28kid93's Avatar
Post
you got mail
G-BODYT56
Jan 14, 2022 11:14 PM
heus
Sep 8, 2015 12:01 PM
1slow93z28
Sep 1, 2015 06:22 PM
97blackformula
Aug 27, 2015 06:02 PM
whitehooptie
Aug 17, 2015 08:35 AM
