2ktransam
03-12-2004, 12:04 AM
I just bought a set of nitto drag radials for my 00 ta. Should I use the water for my burnout or just do a dry burn? Thanks in advance
nitto drag radials2ktransam 03-12-2004, 12:04 AM I just bought a set of nitto drag radials for my 00 ta. Should I use the water for my burnout or just do a dry burn? Thanks in advance 6spdpewterZ 03-12-2004, 12:20 AM Just go in to the water box, spin real quick just enough to get them wet, move up to the dry partand burn the hell out of them.......:bow: Klypto 03-12-2004, 03:56 AM id highly recommend not going THREW it, just go around, chnces are there will be a small amount you will go through anyway, i did this last night an destroyed my rear end, so i know it got the tires nice and HOT(i have a pic of how sticky they were, and it was from 10 min after the burnout, being pushed into a rock pit..) check the link and go to the broken car section http://community.webshots.com/user/klypto cory if not on stock clutch(if m6) upgrade rear before you do what i did..(was my VERY first run) and im 100 percent stock besides for clutch, and snapped it right in half, LUCKILY my best friend is a mechanic, and still 400 with no labor just to replace my 2 rear axles... and finishing pulling the rear tomorrow, and hoping thats all that went wrong... robb4964 03-12-2004, 07:36 AM Originally posted by Klypto id highly recommend not going THREW it, just go around, chnces are there will be a small amount you will go through anyway, i did this last night an destroyed my rear end, so i know it got the tires nice and HOT(i have a pic of how sticky they were, and it was from 10 min after the burnout, being pushed into a rock pit..) check the link and go to the broken car section http://community.webshots.com/user/klypto cory if not on stock clutch(if m6) upgrade rear before you do what i did..(was my VERY first run) and im 100 percent stock besides for clutch, and snapped it right in half, LUCKILY my best friend is a mechanic, and still 400 with no labor just to replace my 2 rear axles... and finishing pulling the rear tomorrow, and hoping thats all that went wrong... WOW you srewed that thing up . Split the axles right in half . :rolleyes: Makes me afraid of heating up my tires at all . 6spdpewterZ 03-13-2004, 02:34 AM Well.. I have no broken axles yet.... still have my nittos for street..... BUT, use ET streets @ the track.. 13.2's w/ stock rear end formula383 03-13-2004, 02:04 PM I get in the waterbox and turn the tires over just enough to get wet the go out of water and do the burnout. robb4964 03-13-2004, 05:28 PM I dont need the water . If I drop the clutch at 2000 RPM's the tires spin like crazy . | ||
