jtk
03-11-2004, 06:53 PM
has any one installed a double roller timing chain into a 87 up hyd roller block? what brand did you install?
I was intending to install a edelbrock timing chain and ended up pulling it back off and installing a factory chain because of clearance issues. I ginded the block above the oil galley that fixed most of the problem, but after bolting the cam gear down I find the cam gear dose not have proper clearance between the gear and thrust plate and will not turn. maybe I have a defective unit?...
