big dave 07-18-2002, 09:58 PM In trying to repair the knock retard problem I've been having, I decided to try a 3900 ohm resister in place of the knock sensor. It is my understanding that the resister should effectively take the knock sensor out of the equation and I shouldn't see any knock. Not so. According to the scanmaster, I'm still getting pretty much the same amount of knock as before.(9 degrees and medium throttle in high gear, 3 degrees at WOT, and maximum of 9 degrees in neutral while revving. What else am I missing that can cause timing retard?
kmook 07-18-2002, 10:28 PM Id like to know also since with my new setup its pulling 9* just at idle, hohum, the joyes of driving a tug boat.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines (http://web.camaross.com/cgi-bin/ubbmisc.cgi?action=getannounce&ForumNumber=30&Start=2452276.99&End=2453736&Session=)
Almost Alive: ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on (http://www.geocities.com/kmook123)...
Injuneer 07-19-2002, 08:53 AM First pull the wire off the knock sensor (or the resistor, in your case) and see if that wire is providing 4-6V referenced to ground - use the engine block. That verifies the wiring and the PCM. If you have 4-6V, anything between 3,300-4,500ohms should simulate the KS in a 93-95 engine. Wired of course from the single sensor harness wire to ground. If you are using a 96/97 PCM, I believe it is looking for something more like 100Kohms.
Fred
[This message has been edited by Injuneer 94FormM6 (edited July 19, 2002).]
rskrause 07-19-2002, 09:24 AM It seems easier to me to disable it by reprogramming (provided you have the capability). I gave up on the knock sensor, having spent many hours trying to cure false knock. So I have just zeroed it out in software.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
big dave 07-19-2002, 09:30 AM Fred, when I'm checking this voltage, is it necessary to have the key in the "on" position or will the voltage be constant regardless? Thanks.
SILVERZZ28 07-19-2002, 09:35 AM Key must be on. Double check your resistor and make sure your wire is not bare anywhere .(grounding out)
big dave 07-19-2002, 12:38 PM I cut the wire 4" from the computer and spliced in the wire with the resister from there. I grounded it out on the frame. Are there any other sensors that can instruct the computer to pull timing? I did try another computer but that did nothing to help cure the problem. In fact, I actually got more knock retard with that one I assume because it was a stock computer.
SILVERZZ28 07-19-2002, 03:53 PM just to clarify, You did not put it inline did you. You have the resistor tied to the computer end wire and the othe side of the resistor is just going to a ground? Not sure if anything else will retard the timing. I did not think there was.
<font face="Verdana, Arial" size="2">Originally posted by big dave:
I cut the wire 4" from the computer and spliced in the wire with the resister from there. I grounded it out on the frame. Are there any other sensors that can instruct the computer to pull timing? I did try another computer but that did nothing to help cure the problem. In fact, I actually got more knock retard with that one I assume because it was a stock computer.</font>
big dave 07-19-2002, 06:35 PM That's correct, the wire coming from the computer was connected to the wire with the resister then run directly to a ground. The knock sensor was not being used.
396jon 07-20-2002, 01:27 AM I thought that the wire goes to the knock sensor then th eresistor then ground.....the resistor goes between the sensor and gound?
I ve been meaning to do it....but been to busy....
I ve had the same problem.....been trying to get the time to get edit....
RCF925 07-20-2002, 12:34 PM I second RSKrause, I gave up on the Knock sensor and used Tunercat to zero spark retard tables, No more miss
94 Z28,M6,355ci,8.9 CR Vortech S-Trim w/Aftercooler,Tunercat Prog.,DIY desensitized KM, Forged Internals,Port.&Pol. Heads w/3 angle grind,Bal.&Blue.,Crane 215/224-532/532-112LSA cam, 1.6 RR & Fireball HI-6R Ignition ,36# SVO Inj.,Magnecor Plug wires,Edelbrock Shorty Headers with Flowmaster,High Flow Cat,BBK 58mm TB ,K&N CAI,Luk Clutch,Eibach Pro-Kit w/Panhard Rod ,Global West SFC's,RK Sports 5-way adj. shocks & LCA's, Slotted Rotors, Auburn Posi w/Motive 3.73, Niche J-series 18" rims 10.5 rear,9.5 front,Autometer F/P & A/F & Boost Gauges ETC.
big dave 07-20-2002, 06:36 PM Fred, I checked the voltage and got 4.7 volts. What else can I check and is that voltage sufficient?
Injuneer 07-20-2002, 08:58 PM 4.7V is fine. It almost seems like the PCM isn't seeing the sensor (or the resistor) at all. I don't run a KS, and I run the engine off a MoTeC, but I still use the stock PCM for idle air and the speedometer, so I still have my ScanMaster hooked up. At idle it will show 9-deg retard... it will vary in low single digits when the car is driven, and if I hit the throttle hard it will jump as high as 15-deg. But that is how it reacts with the harness connector hanging loose.
I'm sort of out of ideas on this one. If you hook the single PCM wire to one side of the resistor, and hook the other side of the resistor to ground, check the voltage drop across the resistor, to see if the connections are good.
Fred
big dave 07-21-2002, 10:12 AM Thanks alot for the info/help on this one. I've been battling this for a couple months now and it definitely has an affect on the performance at the track and on the street. I was wondering if I could have a grounding problem somewhere. I can see where the plastic tubing that houses the wires for the o2 and knock sensors has made contact with the headers and am wondering if one of those wires may have been burnt. It is impossible to get down to those wires without dropping the header. The black wire with the white stripe is what I'm particularly concerned about and am trying to find out if that is a ground wire. If so I would like to snip that wire closer to the computer and run that to a more convenient ground if possible to see if that has any effect on the retard.
Tofus 93Z28 07-21-2002, 04:51 PM my friend has a 97ss and is having very similiar problems.. on the scanmaster he is reading 5-12 degrees of knock just off of idle along with various degress of knock through the rpm band..Ok, we have measured resistance on the KS... could not get a steady reading but typically hung around .800-.900k..spiked a couple times to 1-3k. we had 4.98 reference voltage...
we also started it up and tapped on the knock sensor, block and exhaust with a hammer, knock reads 0.. then with no tapping and a very light throttle, knock jumps to 5-12 degrees..... any ideas.....
he also has noticed glowing blue plugs at night..the plugs in it are autolites 106, msd wires and msd 6al unit on the vehicle... modifications to car- 1 3/4" slp headers, and ATI pulley.
FWIW, he reset the computer,(disconnected battery for 4 hours) knock went away for 25 or so miles then back to the bull.
This seems to be a problem thats affecting alot of 97 cars...
Anyone find a cure.....?????????????
Kraest 07-23-2002, 01:01 PM <font face="Verdana, Arial" size="2">Originally posted by rskrause:
Rich Krause
</font>
I hear that.
Mine goes to 0* at 1/2 throttle or more.
Mike
<font face="Verdana, Arial" size="2">Originally posted by Green 96 T/A:
You guys make me laugh. How old are you all? Mike doesnt have any feelings. Calling him names will affect him about as much as running shoes would for a paraplegic's 100yd dash times... Know what I mean?</font>
1994 Sunset Orange Metallic Camaro Z28 Convertible - The Gorgeous and Sadistic Bitch Who Mistreats You and Lets You Down, Yet You Still Keep Her (http://personal.msy.bellsouth.net/msy/k/r/kraest/camaro.htm)
1989 Red Ford Mustang LX 5.0 Convertible - The Dependable Girl Who Treats You Right, Yet Your Mind Wanders Elsewhere (http://personal.msy.bellsouth.net/msy/k/r/kraest/mustang.htm)
RCF925 07-23-2002, 06:03 PM Above 3000 rpm I have 0* timing pulled and just manually adjust with Boost Retard knob in car. Forget the KS or KM, you won't get anywhere
big dave 07-27-2002, 03:36 PM Just an FYI, I tried the resister mod again and for whatever reason, I no longer have the knock. This is the very same resister that didn't work last week...what gives? I've driven the car for a few miles and the guage hasn't moved from 0.0
MadMax350 07-28-2002, 12:07 AM <font face="Verdana, Arial" size="2">Originally posted by big dave:
Just an FYI, I tried the resister mod again and for whatever reason, I no longer have the knock. This is the very same resister that didn't work last week...what gives? I've driven the car for a few miles and the guage hasn't moved from 0.0</font>
You could have had a ground problem. I noticed that you stated that you grounded the resister to the frame in a previous post. Did you do so this time? It is not uncommon for there to be a resistance or ground difference between the engine and the frame/body despite the ground straps. The PCM is grounded to the engine. You should make the resister ground to the engine.
(P.S. I got a 7 ohm difference between my engine and the frame ground with the engine running despite 3 good ground straps)
1987 Trans Am GTA WS6
5.7L SuperRam
4L60-E Trans
3.73 SRD
1987 Pontiac Fiero
3800 Series II SFI
4T60-E Trans
3.33 Final Drive
1987 Chevy S-10 Ext. Cab
4.3L Vortec TBI
4L60-E Trans
3.42 Final Drive
1966 Plymouth Belvedere II
318 Semi-Hemi 2bbl
Torqueflite 727 Trans
http://dtcc.cz28.com
Jesse_Boyer 07-29-2002, 09:18 AM <font face="Verdana, Arial" size="2">Originally posted by MadMax350:
5.7L SuperRam
4L60-E Trans
3.73 SRD
1987 Pontiac Fiero
3800 Series II SFI
4T60-E Trans
3.33 Final Drive
4.3L Vortec TBI
4L60-E Trans
3.42 Final Drive
318 Semi-Hemi 2bbl
</font>
why do we need to know that you have a fiero, an S-10, and a Belvdere? Just razzing you but seems like unnecessary information...
Correction, the Fiero can stay http://web.camaross.com/bb/wink.gif. But it could still be on one line
big dave 07-29-2002, 09:46 AM I ran the ground to the same place I did before using the same wire and resister. Someone else, who has had their knock sensor and resister hooked up to a switch, mentioned that sometimes you have to drive it a bit before the knock goes away totally and other times it goes away right away.
Brandon 95 Z28 07-29-2002, 09:18 PM Which wire coming from the computer is the KS wire?
Brandon
95 Z28 Silver, 6Spd
Mods: Mac Headers/Y-pipe/ offroad pipe, Taylor OVC Wires, Cutout, Pro 5.0, K&N FIPK, GMS Strut Tower Brace,!MAF Screen, !TB Coolant, 1LE Bellow, LT4 KM, Gutted Cat, CSI Electric Water Pump, 160 Thermostat, NGK TR55's,
RedIrocZ-28 07-30-2002, 04:36 AM It seems to me that perhaps a change in the source code or just a zeroing of the KS is in order. What would happen if GM had hired an employee that had forgotten to hook up the KS plug on say 4,000 cars? They would loose their butt in warranty repairs from blown motors. It seems to me that this 9* retard with the KS unplugged is somewhere in the source code or other calibrations on the PCM. I would go along with what Rich said and zero it with Tunercat or what ever your editor program of choice is. It seems like quite a fantastic fix if you are CERTAIN you are not picking up any knock.. flase or real.
MadMax350 08-01-2002, 12:22 AM <font face="Verdana, Arial" size="2">Originally posted by Jesse_Boyer:
Correction, the Fiero can stay http://web.camaross.com/bb/wink.gif. But it could still be on one line</font>
Good question, guess I never got around to shortening my quote on this board.
