dreamer1q 07-07-2002, 02:04 PM I have thought long and hard on this one. I am doing a engine buildup this winter. I plan on spending around 7500.00 dollars. I can go over or under no big deal. I will be going with a 383. The reason I ask this in Advanced Tech is because I want the correct answer. The LT1 block is a two bolt, we all know that. My question is if the block from another vehicle with a 4 bolt main and 2 peice rear main will be the same. I would like to do the the engine while I still can drive my car. If I can build any block, then I can have a 4 bolt main, and just switch the nessceary parts when I do the swap. I know the LT1 is a bit different at times, but will everything bolt up and work like it is suspose to on a non LT1 block? I have a engine builder at work who thinks it will, but I was hoping someone has tried this or looked into it before.
Arrest ME Red 1994 Camaro Z28 Convertible
just a chip and a muffler, well maybe some headers
http://home.attbi.com/~mycamaro/
KTamez 07-07-2002, 02:59 PM You'll need an LT1 specific block. However GM LT1 Crate motors along with LT4s have 4 Bolt Mains. Also any block can be converted to 4 Bolt, or Splayed 4 Bolt caps. That is if your application even really requires the 4 Bolt Mains.....
Kurtis Tamez
LT4-396.com (http://www.lt4-396.com)
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body (http://www.teamnwfbody.org)
dreamer1q 07-07-2002, 04:06 PM What makes it different? Is the actual mount spots different? I'm just wondered. I know I will need the 4 bolt main, just no reason to build a bullet proof lower end and run it with 2 bolt caps. I was hoping to get out of having to have the splayed caps put in. Any idea on what a block is going for from Gm?
Stephen 87 IROC 07-07-2002, 04:30 PM My block only has 2 bolt mains. Using ARP studs, you can make it as strong as a 4 bolt without weakening the cap mounting area.
Stephen's racing page (http://www.hardtail.com)
or check out the race car (http://www.hardtail.com/iroc.html)
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 115.91
Best corrected ET: 11.114
Altitude corrected rear wheel HP: 457
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association (http://www.calgarydragracing.ab.ca)
joesmith69 07-07-2002, 05:37 PM I agree. In most cases, a 4-bolt is unneccesary. I think a studded 2-bolt is good to the 700hp area in a small block.
The LT1 block is built for reverse cooling. The coolant passages, and I believe head bolts are in a different location then a gen 1 SBC. Just get a used bare LT1 block, and use ARP studs. You'll be fine.
-Joe
79' Z28 4-spd
http://joesmith59.freeservers.com/
*Boycott Lapeer*
NOMAD 07-07-2002, 05:46 PM From what I understand, the flywheel will have to be changed since the bolt pattern is different on the crank snout. Then, the torque converter will be different, and the the tranny... etc...
Buy and LT-1 used, and put studs in everything. Splay it... Buy a 4 bolt LT-1 from a vette if you feel it's necessary. It will hold up.
-Shannon
"Yep, getting drunk at the ol' flower shop"~ Homer Simpson
Http://nomad.cz28.com
Need to Buy stock Throttle Bodies...Email me
'95 White Z-28 T-Tops
Cold Air Intake, Ported MAF, Ported Heads, B&M shift firmer, !cat, !iat,!egr, Home Made MonoBlade, LT4 Hotcam, Cloyes, Taylor 8.5MM, Comp cams pro magnum rockers, Hooker Long Tubes, True Dual 3" exhaust, CSI Water pump, FastKitteN in the passenger seat ;)
Best ET (Stock): 13.84
Soma07 07-07-2002, 06:05 PM On a similar note is it nessecary to have the block aligned bored/honed when using studs vs. bolts?
I would think not since you would still be using the same main caps but what do I know? http://web.camaross.com/bb/tongue.gif
Jason
93 TA, M6
rskrause 07-07-2002, 06:13 PM A number of points need to be clarified. An LT1/4 block has a number of characteristics that make it non-interchangable with a "traditional" SBC. The cooling passages are different, so different heads and intake are required. The distributor is front mounted, and if you want to use a SBC with a distributor it is difficult to fit one under the cowl of a 4th gen. The LT1 PCM needs signals from the Optispark, so you need to run one unless you go for an aftermarket ECU (or plan on using a carb setup).
There are no new LT1/4 blocks available from GM. I suppose some dealer may have some though. Most people feel it isn't worth the trouble to adapt a traditional SBC to fit a 4th gen. The only exception I can think of is an exotic race setup.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
dreamer1q 07-07-2002, 07:36 PM You guys have been very helpful, I appreicate it a lot. I will probably end up finding a used block and having it machined. I understand what alot of people are saying about a 2 bolt being fine in most cases. But I am not totally sure how far I am going to take this. I have the 210cc AFR heads being prot matched to my lt4 intake now. The intake is being hogged out to compensate flow for the blower package I intend on putting on. I have not decided on which package to use, but I will have one. I want the ability to run big numbers. This car is just a toy anyway, so I want it to be a incredible toy. I am planning on a 9.5 to 1 compression ratio, I think that should work and not pop to many gaskets http://web.camaross.com/bb/biggrin.gif Any input on this buildup is appreicated, but the block is the main thing, now I can go find one and start on the lower end of things. Thanks guys
AutoRoc 07-07-2002, 11:24 PM I would think making a 2 bolt block into a 4 bolt splayed block would be a perfect choice.
Buy the caps and get the machine work done...Viola...Goodlock man
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com (http://www.denny.cz28.com)
Eric Bryant 07-08-2002, 11:22 AM <font face="Verdana, Arial" size="2">Originally posted by Soma07:
</font>
All depends - can you hit the same clamping force that was used when the block was originally line-bored? If so, nothing really changes and you don't need to hone the block.
On the other hand, if the cap clamping force changes due to the change from bolts to studs, then it's not a bad idea to clean things up with a quick hone of the mains.
1996 Impala SS - LT4 396, T56
1996 GMC K2500
1992 Buick Roadmaster Estate Wagon
MissedShift 07-10-2002, 10:34 AM Uhhh...correct me if Im wrong, but if you're going to go forced induction, and you've already got the means and the intention of building a custom shortblock, isnt 9.5:1 a little high?
PatrickCarter 07-10-2002, 01:56 PM 9.5:1 to high, for a toy? man I would say too low http://web.camaross.com/bb/smile.gif I would say shoot for 10-10.5:1 and race gas only, afterall it is a toy. http://web.camaross.com/bb/smile.gif
Patrick
Patrick Carter EX '01 HI
94 Quasar Blue Camaro
396 solid roller with AFR heads
www.fastblackformula.com
dreamer1q 07-10-2002, 06:10 PM Yes a toy, but a streetable, bearly, toy. Dont want to have to run to the track to fill up. I figure 9.1 is good. Unless someone has some other input on it?
strokedTA 07-10-2002, 07:09 PM COOL, Rich, Now I have an EXOTIC Race set-up! http://web.camaross.com/bb/biggrin.gif LOL
Really simple actually. http://web.camaross.com/bb/wink.gif
Dave Brown
If a little's good,
More is better,
And too much is just right!!!
rskrause 07-10-2002, 10:37 PM <font face="Verdana, Arial" size="2">Originally posted by strokedTA:
Dave Brown
</font>
Hey Dave: I'd like to know more about your setup (and the logic behind it)!
Rich Krause
"1FASTZ28"
Curt (pres AAMC & ZAA) 07-11-2002, 06:18 AM So what I'm hearing in this thread, it's worthless for me to convert to a studed narrow register straight 4 bolt main with billet caps over a studed two bolt? And the only 4 bolt conversion that's worth the trouble is splayed?
I was going to go to the straight 4 bolt main conversion since it is considerably cheaper than the splayed 4 bolt because they won't have to remachine the registers. I guess I need to think about this some more before I take the block to the machinist.
rskrause 07-11-2002, 08:52 AM <font face="Verdana, Arial" size="2">Originally posted by Curt (pres AAMC & ZAA):
I was going to go to the straight 4 bolt main conversion since it is considerably cheaper than the splayed 4 bolt because they won't have to remachine the registers. I guess I need to think about this some more before I take the block to the machinist.</font>
You could argue that there's no need to use anything other than the stock 2-bolt caps on most buildups. But 4-bolt caps will be a lot stronger. I doubt that the incremental advantage of splayed v. straight caps is of any signficance except for the most extreme buildup. FWIW I am making 733rwhp on straight nodular iron caps.
Rich Krause
"1FASTZ28"
Soma07 07-11-2002, 03:25 PM <font face="Verdana, Arial" size="2">Originally posted by Eric Bryant:
</font>
Thanks Eric!
So I guess its a "try it and see" sort of thing. I guess you would just measure the diameter of the hole to see if its still round after converting to studs?
Thanks,
Jason
strokedTA 07-12-2002, 12:28 PM Rich, What would you like to know?
I thought most people here knew what I had?
The Logic????
Well, for one, I saved over $5000.00 going with a carb.
Where do you think that extra money went? http://web.camaross.com/bb/biggrin.gif
If I was boosted or drove it more on the street, EFI would "maybe" be a better option, but with spray it's not a major benefit.
Dave Brown
If a little's good,
More is better,
rskrause 07-12-2002, 02:08 PM <font face="Verdana, Arial" size="2">Originally posted by strokedTA:
The Logic????
Dave Brown
</font>
You told me what I needed to know (that it's a race setup with a carb). FWIW that makes it "exotic" in my lexicon! For 99.999% of "the rest of us" street and street/strip guys keeping the LT1 with EFI makes more sense.
Rich Krause
"1FASTZ28"
Matt Mc 07-16-2002, 04:46 PM Hey Rich
You said that you were making over 700 RWHP on iron caps. So is your set up a factor 2 bolt or 4 bolt bottom end?
Matt mc
Matt Mc 07-27-2002, 02:42 PM ?
Jerm93z28 07-31-2002, 05:43 PM <font face="Verdana, Arial" size="2">Originally posted by strokedTA:
</font>
http://web.camaross.com/bb/eek.gif http://web.camaross.com/bb/eek.gif you saved $5,000 by going to a carb!?!? how so?
jeremy
'93 z28 m6 (Purple Pearl Metallic)
stock shortblock, 230/236 cam, mildly ported heads, hooker longtubes, csi waterpump, all the usual bolton stuff.....
7.98 @ 88.7mph 1.84 60' (1/8mi)
KTamez 07-31-2002, 07:40 PM Take my Scenario:
$350 LT4 Intake
$300 Porting
$2000 FAST
$500 Injectors
$500 Throttle Body
$100 Fuel Pump
$500 Laptop
$100 Regulator
$275 Opti
$4625 Total
or
$350 Single Plane Intake
$300 Porting
$200 Machining for LT1 Bolt Pattern (Just a guess)
$1000 Carb
$300 Fuel Pump (Not counting new braided lines etc, since OEM can't be used)
$100 Regulator
$200 Distributor
$2650 Total
Note that not everyone might need that $2000 FAST system.
I'm sure I'm missing some things, but when it comes down to it, if you have a perfectly good LT1 setup, its hardly worth going to a carb. Consider you wouldn't need to buy the intake, Opti, and a few other items.
No doubt Dave's personal scenario is slightly different, being a Gen1 SBCbut I think he's pretty well overexagerating there at $5k. http://web.camaross.com/bb/wink.gif
Kurtis Tamez
97 Z28 LT4-396
94 Firehawk LT1-396
rskrause 07-31-2002, 11:57 PM <font face="Verdana, Arial" size="2">Originally posted by Matt Mc:
Hey Rich
Matt mc</font>
Factory 2-bolt converted to 4-bolt using GM straight nodular iron caps pn 3932482. It's what my engine builder reccomended so I went with them. No problems so far, though my setup is not a high-revver (6K rpm redline).
Rich Krause
"1FASTZ28"
Jim S. '95 Z28 11-07-2002, 10:24 AM Originally posted by rskrause
Was this more of a budget issue or a means of averting "stretch" with billet caps?
Faccnator 11-07-2002, 01:56 PM strokedTA,
I have a carbed going into my 95 camaro in about two weeks. We are just going to tackle all the problems (cowl clearance, accessories, etc.....) as we get there but if you have done it any suggesstions or pics would be great.
Faccnator
rskrause 11-07-2002, 07:26 PM Originally posted by Jim S. '95 Z28
He never really gave me much of a reason. Maybe he had a set laying around? He is sort of opinionated and I went along with it. All I can say is, it works!
Rich Krause
