1/4 mi track tips
NEOS97SS
03-10-2004, 02:09 PM
any cheap or free tricks to make the car faster like weight reduction or launch advice
my mods are listed below and i went 13.60 im putin in a hotcam and a 2400 stall and i want a 12.9
ive already removed the rear seats, passenger seat, floor mats, rear divider, spare and jack, emptied washer fluid bottle, remoevd front sway bar and im running on bfg kdws 2754017's @20psi any other ideas
and oh yeah im racing at 1300 asl with crap track prep. my best 60 ever has been a 2.1
thanks
MustangEater82
03-10-2004, 02:15 PM
Pump up the front tire pressures to like 50psi hot... its about 45 psi cold(the reccomended limit), and will be that temp when running since the fronts will be pretty cool going down the strip...
jsut to warn you makes the front end float a little more, but I assume you will already be careful since you have an !swaybar up front.
robvas
03-10-2004, 03:05 PM
thanks
2400 is a little small for a hotcam.
KDWS's suck for the strip.
Get some Nittos, leave your 17's at home
NEOS97SS
03-10-2004, 03:23 PM
which do you guys reccomend, 275 DR's on 17s or 255 DR's on 16's and i cant stand nitto's so ill be gettin bfg DR's
