Heating up ET streets
1BADAIR
03-09-2004, 10:02 PM
Those of you with M6's and 4.10 gears. Do you use 1st or 2nd gear to heat them up? How long of a burn out do you do?
Stephen 87 IROC
03-10-2004, 01:02 AM
A higher gear should be used since you want tire speed to heat them up. You're not trying to spin a dry tire because you've just gone through a water box. Once the tire is wet it spins easier. A wet tire in a burnout will heat up the tire better and won't wear off rubber as quickly as trying to spin a dry tire.
Do the burnout in second gear. If you can, do it in third.
I use a powerglide tranny. I start in first and as soon as my rpms come up I shift to high and hold it around 5000 rpm. I'd guess and say the tires are spinning at about 90-100 mph during my burnout.
rskrause
03-12-2004, 10:39 PM
With 4.10's you can probably even start your burnout in 2nd, just don't slip the clutch too much. If you have to, start in first and shift to second. A line lock really helps.
Rich Krause
