Adding Hal QA1's and K-member!
T/A lt1
03-09-2004, 02:36 PM
I broke the main caps in my LT1 so while I am putting a steel crank, h-beam rods, new low tension rings and a new cam I will also be adding a BMR K-memeber with solid mounts and a set of Hal's. Last time the car was at the track I had a problem with spinning and it may have had a little to do with track prep but the best I got was a couple 1.66 60's and the worst was 1.69. The car has run quicker 60's than that before with less power so I know it was spinning. How much could the extra weight off the front and the addition of adjustable struts really help? I am hoping lower 1.5's on motor and 1.4's on N2o what do you guys think? Later Clint
95Bird
03-10-2004, 10:31 AM
I think that you should be able to get that 60' down with your new mods. The front raising quicker will have the most affect on it and the lighter weight that it has to lift is always a good thing.
Chris'SS #2152
03-10-2004, 10:44 AM
Sorry to hear about the breakage but that 60' should come down with your new mods. I am getting ready for sim. mods myself and hope to get down there also with my 60'
T/A lt1
03-12-2004, 09:21 AM
I hope it works guys b/c I have a few things done already but it really never hooks up hard. I have relocation brackets, poly bushings in boxed in rear control arms, removed front swaybar and a RR airbag@18-21psi. The best I have done is 1.58 on the gas and spinning. Thanks Later Clint
