BOOST/NOS/COMPRESSION
BOOST FED 95Z
07-08-2002, 01:32 AM
I am putting togethor a 355 and im going to run around 10-12 psi boost aftercooled, and 100-150 nos. What compression pistons do I need and which pistons to go with? I have 6inch rods. This is a stock headed car with a cc306, and full exaust. Thanks for the help.
1995 MYSTIC Z28
M6
T-TOPS
CHROME Y2K VETTE WHEELS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
CHASSIS ENGINEERING 8 PT.
HARWOOD 2.5" COWL HOOD
NITTO 275-40-17 DR'S
rskrause
07-08-2002, 05:47 AM
You are going to have a problem with your setup. To run 10-12psi + N2O on pump gas you want a CR <9:1. The biggest dish I have seen is -21cc which will give ~9.75:1 with stock CC volume. I would get a set of -21cc pistons and pray a lot! Alternatively, only run the N2O with race gas.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
Jesse_Boyer
07-08-2002, 09:47 AM
Rich, I remember seeing a -31 cc dish somewhere. If it wasn't 31, it was low 30's.
rskrause
07-08-2002, 01:10 PM
<font face="Verdana, Arial" size="2">Originally posted by Jesse_Boyer:
Rich, I remember seeing a -31 cc dish somewhere. If it wasn't 31, it was low 30's.</font>
Jesse: thanks for the info. If that's the case, I say "go for it"with the caution that some pistons with alarge dish have weak crowns.
Rich Krause
"1FASTZ28"
BluEyes
07-08-2002, 10:11 PM
keep the quench (piston-head clearance @TDC) tight, polish the chambers and piston crowns, maybe even get a ceramic coating on the crowns. That'll help avoid detonation. (also polishing the chambers will increase cc a bit)
Lastly, having a cam with a later intake valve closing point will reduce cylinder pressures.
BOOST FED 95Z
07-08-2002, 11:22 PM
Thanks for the help guys. What pistons would you recommend and where to get them? A website? THanks
1995 MYSTIC Z28
M6
T-TOPS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
rskrause
07-09-2002, 07:53 AM
<font face="Verdana, Arial" size="2">Originally posted by BOOST FED 95Z:
</font>
http://www.jepistons.com/automotive.asp
Rich Krause
"1FASTZ28"
Jesse_Boyer
07-09-2002, 01:00 PM
Anyone do a search for -31cc dish pistons? I know its been discussed before on this site. Maybe they were custom.
rskrause
07-09-2002, 01:07 PM
Anyone do a search for -31cc dish pistons? I know its been discussed before on this site. Maybe they were custom.</font>
http://www.jepistons.com/pdf/2002-je4-13.pdf
Rich Krause
"1FASTZ28"
1993lt1
07-09-2002, 08:01 PM
21cc dish on 355 lt1 is about 9.1 to 1.21cc dish on 383 lt1 is about 9.7 to 1
nosfed
07-10-2002, 01:05 PM
Why are you using a 306 for that setup?
