MASC performance Heads and cam packages now available!!
Old Mar 8, 2004 | 09:55 PM
94REDSTALLIONZ's Avatar
Hello all,
We are proud to introduce our Stage I and Stage II LS1/LS6 Cylinder head's and cam packages!! The stage 2 LS6 heads and cam package is suprisingly affordable and there is no LS6 core charge either..This package with longtube headders and the usual bolt on's has been proven to produce over 450 Rear wheel Horsepower naturally aspirated!! Average testing is around 430 rear wheel hp and over 400 ft. lbs as well with great driveability.Here is a break down of the packages in order from stage I up to the stage 2 LS6 package.
Stage I 5.7 or 5.3 liter LS1 Head's and cam package:
Includes Stage I 5.7L or 5.3 LS1 Cylinder heads Fully ported with stock valves (flow 289cfm@.600" lift int ,212cfm@.600 exh), Custom-Grind Camshaft, Hardened Pushrods, Heads & Cam GM Bolt & Gasket Kit,custom computer tuning,all fluid's and full installation included.No core charge on any parts! $3,100.00 installed.
Stage II 5.7 or 5.3 liter LS1 Cylinder Heads and cam package:
Includes Stage II 5.7 or 5.3 LS1 Cylinder heads Fully ported with 2.02/1.57 stainless steel race valves and .650" lift springs (flow 297cfm@.600" lift int,220cfm@.600" exh),Custom-Grind Camshaft, Hardened Pushrods, Heads & Cam GM Bolt & Gasket Kit,custom computer tuning,all fluid's and full installation included.No core charge on any parts! $3,659.00 installed.
Stage II LS6 heads and cam package:
Includes Stage II Fully ported LS6 cylinder head's with 2.02/1.57 stainless steel race valves,.650" lift valve spring's and custom titanium retainers (flow 311cfm@.600" int,230cfm@.600" exh)Custom-Grind Camshaft, Hardened Pushrods, Heads & Cam GM Bolt & Gasket Kit,custom computer tuning,all fluid's and full installation included.No core charge on any parts! $4,100.00 installed.
All of these packages are installed in house at Modern American Sports Cars in Orlando,FL. If you wish to place a package order or for information on any questions you may have, Please feel free to e-mail or call us at lt1brutus@mascperformance.com or Z28vf@aol.com or 1-877-891-5550. Thank's,
Carter@MASC
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
97 RedSS
Jun 10, 2003 07:58 PM
NED4SPD
Sep 16, 2002 10:45 PM
