hellostop
03-08-2004, 09:52 PM
Most burned pistons seem to be on number 7 & 8, why?
Would addiing pyrometers on header exhaust tubes for 7 & 8 help in determining overlylean?
Also, how do I expand the 4" solid intake pipe on my D1 ? I am trying to install used kit on 94Z.?
Willie
03-08-2004, 11:55 PM
Simple. The back cylinders run leaner because of unequal air distribution. They get more air than the front cylinders. The "solution", if you can call it that, is to have your set of injectors flow tested, then reinstalled with the ones that flow the most on the rearmost cylinders. This is one of those "secrets" most don't know about.... until now....
Actually, yes. I have my EGT on #7 and tune to it.
Can't help here. I own a third gen.
SMOKNZ
03-09-2004, 05:35 AM
my only burned piston was #1...
hellostop
03-09-2004, 03:12 PM
I'm not sure what a proper temp is for a header tube on a properly tuned motor? I'm sure the temp goes up when the boost is on. There must be some safe max temp to watch for?
If they were not so expensive, I quess install one on each tube would be a good idea.
Maybe 7&8 lean out due to the air being pushed / blown to the rear of the manifold and thus filling those cylinders first?
