Installed Pacesetters! One problem..
BigRedZ28
03-06-2004, 02:29 AM
Okay so I installed my pacesetters and Y-pipe to the Hooker cat back today! Looks good, sounds alittle loud but not too bad actually! Cool roar when I lay on it! But there is a knocking when I idle like the driveshaft is hitting the floor, and it seems the headers are knocking abit.. it was a tight fit.. is this normal and will it fix itself?
Thanks.
Killaz
03-06-2004, 04:29 AM
notch the k member and it will go away
chpmnsws6
03-06-2004, 04:42 AM
mine do it also. notch the k-member or lay into it with something inbetween the k-member and the header.... that will bend it out some maybe
BigRedZ28
03-06-2004, 02:56 PM
Hmm.... it's only when I am sitting still with it in park does the nocking occur badly. I was told it was my Y-pipe hitting the heat shield. . . and that I could take the heatshield off or just deal with it. Meh. It is pretty loud, I guess thats my fault for not buying Cats. -.-;
jakesnake123957
03-06-2004, 04:47 PM
There is 1/8 inch heat shield asbestos stuff,I got it from work,but industrial supply stores should have it.install it between your pipe and heat shield>Jake
chpmnsws6
03-06-2004, 04:50 PM
put a wrench or something in there inbetween the shield and the y-pipe then goose it real quick to twist the engine. take the "filler" out and see if it helped any
cats = bad :p
Mikael
03-06-2004, 05:41 PM
A piece of rubber hose between the header and floorboard works great and is much easier.
