Ls1 Procharger Question
robb4964
03-06-2004, 01:04 AM
Hello , I was wondering if someone could tell me what the max boost I can run on a stock LS1 engine with ATi procharger .
Also wondering what kind of quarter mile times im looking at with 6lbs and dual intercoolers .....Thanks fella's , Robb
robb4964
03-06-2004, 05:48 PM
TTT -----Noone knows ? I have done search after search and cant find much Info . :cry:
97WS6SCharged
03-06-2004, 10:27 PM
I think ATI claims 8 or 9 PSI on their intercooled kits. 6 PSI on an LS1 will probably get you 12s in the 1/4 depending on traction and what not. :)
robb4964
03-06-2004, 10:44 PM
Originally posted by 97WS6SCharged
I think ATI claims 8 or 9 PSI on their intercooled kits. 6 PSI on an LS1 will probably get you 12s in the 1/4 depending on traction and what not. :) 12's ? I was hoping high 11's ! I can hit 12's right now stock ,w/drag radials , easy .
If It can handle 8lb's , ill have to get the pulley for it . Im getting a 13lb pulley with it..also a 6lb . I have heard averag gains are 450hp form a stock LS1, and up to 540 with a stock ls1 . Thanks for the reply man , anyone else ?
97WS6SCharged
03-06-2004, 11:18 PM
I meant 12's on street tires. With drag radials, 11's should be possible assuming the stock rearend doesn't give out. :)
robb4964
03-06-2004, 11:21 PM
I meant 12's on street tires. With drag radials, 11's should be possible assuming the stock rearend doesn't give out. :) Im hoping to get a cam thats good for boost . I got a pretty good cam , but the lobe seperation is not good for boost . Im proably gonna sell the cam and get headers and cam w/my Forced unduction and maybe crank the PSI up to 8lb's . Its my weekend car so It wont see constant action . :D
97WS6SCharged
03-06-2004, 11:34 PM
What happenned to stock? :think:
robb4964
03-06-2004, 11:39 PM
What happenned to stock? :think: The cam is in my closet . Not in the car yet . I was waiting to put it in for when I get my headers and what not . I have to put a clutch in it , the clutch is GONE . All that HP wont do many any good if its slipping away . I already have a clutch , but Like I said I want it all done at one time .
I know the car will run a 12 , It pulls like a train . It needs to hook up first though .
D James
03-07-2004, 12:54 AM
Are you doing this stuff yourself, if so you better get working, I couldn't imagine wanting to do a cam install, new clutch, headers, and charger all at once, thats alot of work to take on without a few weekends in between. Also i would sell your new cam and get one made for the charger, why go through all the work just to change it later
97WS6SCharged
03-07-2004, 01:10 AM
Sounds like me fixing my head gaskets this week. Blown head gasket? Time for a new cam and valve train, and don't forget the P&P job on the heads while you're at it. I still have to put everything back together and strap the Vortech back on. :)
robb4964
03-07-2004, 10:28 AM
Originally posted by D James
Are you doing this stuff yourself, if so you better get working, I couldn't imagine wanting to do a cam install, new clutch, headers, and charger all at once, thats alot of work to take on without a few weekends in between. Also i would sell your new cam and get one made for the charger, why go through all the work just to change it later Yeah , thats kinda what I said I was doin James . I am not going to instal the cam . I am waiting for everything to go thrue with the SC before I sell it , but it is not going in the car .
I am putting on the headers and SC at the same time . I have 2 other cars so its not like im going to be stuck w/out a ride . I wont be in a hurry , I can work on it on my days of and after work .
