Installing NX kit next week advice needed
Jeff 96 SS
03-05-2004, 08:57 PM
I will be installing my NX wet kit next week I think I have everything figured out but would love any advice.
I'm installing this on my 396 D1 set up with TH400 and T-brake. the 396 is built with great parts and is about 9to1 compression 15-17#s of boost just depends if the belt holds. I'm not sure how much to spray I will probably run the 75 shot. Can I run More? How much extra timing are you guys pulling when you run on the spray?
I will be installing a two step and a window switch I have a MSD6btm and another MSD box I can install pills in to pull timing. i also bought a delay box I was thinking spraying out of the hole may be to much I'll play with that at the track I may delay it it a couple tenths. Wiring all this stuff up will be The fun part any advice on this?
I will be foot braking most of the time T-brake use only on special occasions :)
Jeff
96 SS BLOWN
96 TA 396 D1
Jeff 96 SS
03-08-2004, 04:34 PM
cmon guys no tips lessons learned anything?
Jeff
96 SS BLOWN
96 TA 396 D1
OBE1 95Z28
03-09-2004, 09:02 PM
You'll need to tune your jets sizes on the dyno with a wide band O2 setup. I found that the NX recommended jet sizes for a 75 shot to be way to rich. I find that I don't get any intake temperature rise down the quarter mile went I'm spraying on top of my 10# Votech setup. I'm also running a Vortech aftercooler.
