sharp28
09-11-2002, 06:32 PM
P1351-- Ignition coil control circuit high voltage
Has anybody dealt with this code before?
code P1351 anybody?sharp28 09-11-2002, 06:32 PM P1351-- Ignition coil control circuit high voltage Has anybody dealt with this code before? kmook 09-11-2002, 08:03 PM I see you have a 96Z in another post, I will get this over to 'Computer diagnostics/programming' where its more suited. Thanks. ------------------ Ken Mook - 97' SS #2544 Advanced Tech Posting Guidelines (http://web.camaross.com/cgi-bin/ubbmisc.cgi?action=getannounce&ForumNumber=30&Start=2452276.99&End=2453736&Session=) 383 - D1, CAS Custom I/C System, 74# Siemens, LJ's Black Box, Kenne Bell Boost-a-pump, Stage 2 Heads, 3100 Lobe XE Cam, Godzilla BOV, Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on (http://www.geocities.com/kmook123)... [This message has been edited by kmook (edited September 11, 2002).] sharp28 09-20-2002, 04:22 PM problem solved! replaced coil and coil wire, code went away. Also moved the coil bracket away from the head, but i don't think that had anything to do with it | ||
