I want to get rid of my TPI...
Old Mar 2, 2004 | 08:33 PM
dj haf's Avatar
i want to ditch the TPI and go for something better... i like the MR, but if the LT1 intake gives the same power that the MR dishes out, i'd rather go with the LT1 intake. the HSR looks too ugly to me... but it's pretty cheap. i really don't plan on revving the iroc past 6 grand, and i don't want to waste a lot of money on the intake either... so here're my questions:
1] from 1k to 6k (rpm), which intake produces the most low end torque and highest top end hp?
2] i have ported stock heads... if i get the LT1 intake now and later wanted to get a set of AFR 195's, would there be a problem installing the intake on the AFR's?
3] look at my sig... which intake do you think i'd get the most gains from, and how much of a gain do you think that would be?
4] does anyone know how much more power there is to gain from porting out the LT1 intake?
i have a cam that's rpm range is from 1500 to 5500, but im sure i wont have a problem pulling it to 6k from time to time. the LT1 intake looks like the best bang for the buck, but if the HSR can pull more power up to 6k, then i'd spend the extra money on that.... i just wont pop the hood for ppl due to the fact that it looks like a silver brick ontop of the intake manifold, lol
im just getting tired of the limit tpi has... i want to run deep into the 12's, or maybe touch 11's without nitrous. i know you have to match your whole setup accordenly, so thats why im looking for an intake that would compliment my setup that i have so far. im planning on getting a TC after i get my intake, so i know what stall to get. im kinda iffy about the HSR because i've heard mixed reviews about it... i've heard of some ppl only gaining a couple tenths after the install, and some even losing power, so i don't know if i even want to go there at all, lol
thanks you guys for reading all my crap, and for your input... take care
Old Mar 3, 2004 | 12:07 AM
chevyman502bb's Avatar
dj, shut up and get the LT1 intake like i told ya
Old Mar 3, 2004 | 12:23 AM
stanghunter211's Avatar
If you sell that tpi top end, let me know, I would be very interested
Will
Old Mar 3, 2004 | 12:28 AM
Aklaim's Avatar
Will, you have a TPI motor.....why the need for a new top end?
Old Mar 3, 2004 | 12:30 AM
might dabble in porting and what not, need a like system to learn on. Also want to get some pieces ceramic coated for show, would be nice to have a set to work with off the car so as not tokeep her down for so long ...
Will
Old Mar 3, 2004 | 12:46 AM
dj haf's Avatar
ill let you know wuts up will
Old Mar 3, 2004 | 12:47 AM
thanks brother
Will
Old Mar 3, 2004 | 08:21 AM
Black6SpdTA's Avatar
dj haf,
I've got a LT1 Intake/Fuels rails I might be selling within 2wks. I'll let you know.
-Corey
Old Mar 3, 2004 | 11:16 AM
Z28James's Avatar
Originally posted by Rippin92RS
dj haf,
-Corey
I dont want to see you saying this stuff corey.
Old Mar 3, 2004 | 12:05 PM
StealthElephant's Avatar
Stang, I did a 350 swap, my 305 TPI motor is sitting on the floor of my bosses' garage collecting dust. Everything is there except the wiring harness is pretty butchered.
Old Mar 3, 2004 | 01:54 PM
Zepher's Avatar
For your swap, I'd go miniram to get every last ounce of power, but is it worth the extra $500-700 to you?
Old Mar 3, 2004 | 03:09 PM
dj haf's Avatar
doesn't the HSR make the same power as the MR up to 6k, though the MR keeps pulling up to around 7k while the HSR dies out?
Old Mar 3, 2004 | 08:54 PM
formularpm's Avatar
It depends on the combo.
Old Mar 3, 2004 | 09:22 PM
dj haf's Avatar
im still debating between the LT1 intake and the HSR for my combo... look at my sig. later, afr 195's are going on, and probably a s/c if i feel the need for more power (and if i have the flow to do it)
Old Mar 4, 2004 | 01:37 AM
Stealth, would you be willing to sell off the top end, just need the TPI setup, for a decent price that is. I don't really need it, which is why I was gonna take his setup. I mainly need plenum/ fuel rails / and some other odds and ends
Thanks man
Will
