What does PCMForless actually program in PCM to gain the extra 10 horse???
Old Aug 28, 2002 | 12:03 PM
Z_Maniac's Avatar
Post What does PCMForless actually program in PCM to gain the extra 10 horse???
I keep reading threads here about PCM ForLess
can gain you an additional 10 horse just by recalibrating the PCM and tuning some fuel tables on mildly-stock cars??? If anyone know exactly was is being changed and the tables it will be helpful.
1994 Arctic White Hardtop Z28
Flowmaster 3" Catback, Custom 4" CAI, Borla Y-Pipe, TB Bypass, 160 Stat, Accell 300+ 8MM Racewire, NGKTR6 plugs, LT1Edit, 75 Shot, IAC Relocated, 1st Gear MOD.
DYNO: Bone stock w/ exception of Catback. 269rwhp/318rwtq (SAE Corrected)
Need to be installed:
CC305 Kit, 3.42 LS1 stock rearend, Hooker Coated Shorties 1-5/8, SLP Level 1 Susp. Pkg.
Old Aug 28, 2002 | 12:06 PM
Hal Fisher's Avatar
Post
Stock would have a lot to gain by reducing the fuel to air PE tables. Getting them closer to 13 or 13.5 instead of 11.7 would help a lot I imagine.
Hal
Old Aug 28, 2002 | 05:30 PM
turbo_Z's Avatar
Post
he just adds a couple degrees of timing advance and claims 10 hp. its pretty much the same thing as the power tune with the hpp.
Brad
1997 Z28 M6
T-tops, ZR1 SS rims, all options, SLP Dual/Dual, cutout, !CAGS, FIPK, LT4 KM, Air Foil, TB bypass, pro 5.0, OBD1, !EGR, !AIR, CSI waterpump, 160* thermostat, 1LE intake elbow, PCM tuning by, www.PCMFORLESS.com , MSD superconductors, singe-cat SLP shorties minus the cat!
Old Aug 29, 2002 | 12:20 PM
Dr.Mudge's Avatar
Post
They should lean it out up top a bit, but its not safe to do that over mail order, since there is no way to know for sure how much they can do safely.
If you want to done right, do it yourself.
HarleyZ28
Oct 5, 2015 06:23 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
Latronaxe
Jul 17, 2015 11:55 AM
RUNMYTA
Jul 15, 2015 07:50 PM
