tuner cat vs tuner cat rt
1FASASZ
02-29-2004, 11:21 PM
im getting ready to order a tuner cat, so wich one should i get? does anyone here use the rt version?
thanks
Dan K
02-29-2004, 11:41 PM
Pretty sure we can't use the rt version. Although I'd love to be able to change things while the car is running like DFI and such!
1FASASZ
03-01-2004, 08:39 PM
well that sucks :mad:
sweetassz
03-09-2004, 01:28 AM
TC's sight says it will work but you need a $180 Romulator.
SVT Killer LV
03-10-2004, 04:25 PM
If I was keeping my Z28, Tuner Cat RT would most definately be a purchase...
97Z-M6
03-10-2004, 05:50 PM
sence when.
this is a quote from there site:
Note: The Romulator I only supports EPROM’s up to 256K in size. If you select an ECM Definition File for a calibration that uses a larger EPROM, such as the $0D ECM Definition File, the program will immediately disconnect from the Romulator and revert to normal ‘off-line’ (non-real-time) operation. The Romulator II does support EPROM's up to 512K in size. The Romulator also does not support the FLASH based PCM’s supported by the $EE ECM Definition File.
sweetassz
03-11-2004, 01:00 AM
Originally posted by 97Z-M6
sence when.
That is true, but; on the ecm def file page it states otherwise. Here is the link: http://www.tunercat.com/tnr_desc/do_tc.html
Click on rt tuner then on ecm definition file.
DOOM Master
03-11-2004, 02:59 AM
K, but can you scroll down a bit more and see where it says exactly what 97Z-M6 already posted?
Now go to www.xtronics.com and take a look at the ROMulator. You will see that it is only an EPROM supporting device at current time. It does not support PLCC-32 FLASH chips. This is a list of all the devices that the ROMulator currently supports:
27(C)16, 27(C)32, 27(C)64, 27(C)128, 27(C)256, 29C256
(27(C)512 PKT-ROM2 only)
No where on either Tunercat's or Xtronics' sites does it say that it will support 94+ FLASH PCMs. In fact, it states the exact opposite on both, and on TC's it is specifically spelled out!
sweetassz
03-11-2004, 11:31 AM
All I am saying is their ECM def. file page is misleading. Obviously it is not supported. I did not read the disclaimer when I first posted, thats all.
