Internally modify OBDI computer for an OBDII car?
Dan K
07-23-2002, 12:33 AM
I want to swap my 97 Z over to OBDI and was wondering what I have to do in order to just put the OBDI computer in and not have to change anything. Anyone know?
I think the only thing I'd actually have to change is the knock sensor would have to be changed out to an OBDI sensor. Is there any way I can keep the OBDII sensor?
Is there anything else I'll have to change besides figuring out what to do with the knock sensor?
94DROPTOPZ28
07-26-2002, 06:02 AM
I just did a PCM swap in my 97 T/A and all I had to change was the knock sensor and the PCM it was very simple. I tried it with the OBD2 knock sensor and it's not pretty although I heard you can add a resistor or something I'm not quite sure.
Dan K
07-26-2002, 06:12 PM
Yeah, I'd like to keep my OBDII knock sensor so that I could swap the OBDII computer back in if I need to take it in for some warranty work.
This way I'm not swapping knock sensors all the time.
Raped Ape
08-02-2002, 10:11 PM
PCMFORLESS.com has modded OBD1 computers for the OBD2 cars that you do not have to change anything but the PCM. Programmed and shipped is $290 to your door. Your old pcm can be swapped right back in too. http://web.camaross.com/bb/smile.gif
Dan K
08-03-2002, 10:12 AM
Yeah, I know. I was looking for someone that knew how to modify the computer so that I could just do it.
But I e-mailed Bryan @ pcmforless and he's hooking me up with a really good deal on a modified computer with a stock program so that I can just do the modifications myself.
