ROCKN SS
07-28-2002, 07:45 PM
I have a '97 SS with 15,000 miles on the odometer and believe that it is not staying in closed loop when it should. I have a Cyberdyne Air/Fuel gauge and on a recent trip I noticed that when cruising sometimes the gauge would just show constant rich instead of fluctuating around like normal. This was occuring under minimal load conditions.
I have AutoTap so I hooked it up and first checked for error codes and had none. I ran a log looking at the O2's and the commanded Air/Fuel ratio. When just cruising the commanded Air/Fuel ratio would randomly change from 14.7 to 13.8. When I accelerated hard the commanded Air/Fuel ratio would go to around 12 (correct I think). When the command Air/Fuel ratio is 14.7 the O2 logs fluctuate as expected and when it is 13.8 the O2 log holds at around .9XX.
I thought that there was a parameter to tell weather the computer was in open or closed loop but I couldn't find it. However, by the commanded Air/Fuel ratio I believe that it is going in and out of closed loop.
Does anyone have any ideas what to look for?
