What is my shift RPM?
96z
07-26-2002, 10:26 PM
Dumb question but where in the LT1 edit program is your shift point RPM located? In the transmission section? If so mine says 5700 RPMs...
Also what is normal and hot shift RPM??
96 black Z28 A4
GTP heads, GTP cam, bolt ons...
Mattucci Motorsports WNYFA FLFB
So far...12.7@108...need more practice...
The Z (http://community.webshots.com/user/mattscamaroz28)
s_willis
07-29-2002, 06:06 PM
You will find the shiftpoint part in the "normal mode Shift points vs MPH" or Performance mode shift points vs MPH.That would be on the first window that comes up under A4 transmission. Kickdown and hot shift (WOT) shift points go by rpm AND mph. Both values have to be met for the trans to shift. http://web.camaross.com/bb/wink.gif Otherwise the trans shifts according to mph and %Throttle position.
Michigan Skip
Michigan Skip's Flamed 95 (http://camaroz28.cardomain.com/id/s_willis)
95Z28, K&N TPIS 150hp NOS & 27mpg!
MSD 6AL, Window switch,Ford SVO 24# injectors,
2.73's (3.42's to come) Edelbrock headers, Flowmaster exhaust
BMR SFC,LCA,STB
[This message has been edited by s_willis (edited July 29, 2002).]
