N.W. LT4
07-11-2002, 12:33 AM
I'm doing the install tomorrow and want to know if I can get this cam to pass emissions here in Wa. State
thanks
thanks
Comp Cams 230/236 and Emissions ?N.W. LT4 07-11-2002, 12:33 AM I'm doing the install tomorrow and want to know if I can get this cam to pass emissions here in Wa. State thanks ScLeCo 07-18-2002, 01:14 AM LMAO I wouldn't bet on it, Im assuming you got headers, cats?? ------------------ //BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT... N.W. LT4 07-18-2002, 01:26 AM LYAO huh. I'll keep you posted. RichJ 07-20-2002, 09:35 AM Don't listen to the guy above. He doesn't know what he's talking about. A 230/236 will easily pass emissions... ...with a 116 LSA! http://web.camaross.com/bb/smile.gif Rich CanadianZ 07-21-2002, 02:17 PM I have heard of people being able to get a CC306 to pass and the XE 230/236 isn't too far off of that. You will need cats for sure and a special tune that you put on as soon as you pull up to the emissions place. The car will not be able to drive with the tune necessary to pass. (if it does) CanadianZ | ||
