first start after heads & cam
Old Feb 26, 2004 | 05:46 PM
1FASASZ's Avatar
my head and cam install is olmost complete. im getting freescan and tunnercat what should i change before i first start the car. or should i just start it, scan it and go from there. does anyone have any links for tunning for begginers
thanks
shawn
Old Feb 28, 2004 | 11:02 AM
1FASASZ's Avatar
anyone???
Old Feb 28, 2004 | 11:11 AM
Dan K's Avatar
If you're still running a stock program you need to change quite a bit before you should fire the car. You should set it up for the 30#injectors and do a little fiddling idle rpm and timing so that it will idle right.
If you're still running the stock program and would like a little help setting up one for your combination shoot me a pm.
Old Feb 28, 2004 | 11:34 AM
1FASASZ's Avatar
Smile
sent you a pm
InfernalVortex
Jan 17, 2015 09:35 AM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
