Clutch Replacement
Old Feb 23, 2004 | 09:19 AM
lymelizzard's Avatar
Clutch Replacement
As subject says I will be haveing my clutch changed out failry soon, I will be going with slp clutch and pressure plate. While clutch is being replaced what other nice prevenitive service should be done. I was thinking changing u-joints out, possibly a shifter upgrade at same time. Any other items to check while this is being done?
Old Feb 25, 2004 | 07:25 AM
missetti's Avatar
Take the hydrulic line off that runs between the master cylinder, and the slave cylinder. There is a restrictor inside that needs to be drilled out. Flush the line out, and reinstall. Makes a world of difference. Keeps the clutch from slipping when you start grabbing gears.
Old Feb 25, 2004 | 11:18 AM
number1's Avatar
Serious? I've never heard about that. Can you explain this a little more?
Old Feb 25, 2004 | 11:57 AM
chpmnsws6's Avatar
is that with the lt1's also? i thought it was just for the ls1's
Old Feb 25, 2004 | 06:17 PM
MadMaxz28's Avatar
YES DO IT! pull the braded line out of the Master cylinder take a small drillbit and drill out the restrictor at the end of the line. makes a guge difference!
Old Feb 26, 2004 | 03:38 PM
93turbo5oh's Avatar
arent you supposed to put a new master/slave on it anyway?
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
